Shock adjuster question
Old Dec 27, 2009 | 07:45 AM
2006FLST's Avatar
2006FLST
Originally Posted by BigSeaDaddy
I do not think that is right. I have not done it yet but will. The stock deluxe shocks do come lowered (longer) but you can disable the shocks and put in the longer $20 buck ebay bolt, dropping the bike a full 2.5 inches. Rereading the OP post he bought the shocks with the lowering bolt already installed and only had to mount them up. Were as I am going to compress the springs and swap the bolts until I can afford an air ride.
Now if I am wrong please some tell me now!
You are correct with me buying the shocks with the lowering kit installed. They are on ebay if you just look.
Old Dec 27, 2009 | 09:22 AM
BigSeaDaddy's Avatar
BigSeaDaddy
Oh I am sure they are and i have seen them....the point of my post is that you can use the lowering bolts on the stock deluxe shocks.
If I did not have other things I wanted to do (budget) I would go your route but for 20 bucks plus any blood loss from me is not a bad deal.
Your bike looks great by the way!
Old Dec 27, 2009 | 09:32 AM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
Yes... you are correct BSD....I used these bolts in my stock Deluxe shocks and everythng was a OK...Just make sure to use that spanner wrench and tighten them up all the way as stock pre-load is set for about 175 lbs. The ride isn't bad riding 1-up. As for 2-up riding my OL' a$$ did catch air on certain big bumps. It was very rare but it happened...
Old Dec 27, 2009 | 12:46 PM
2006FLST's Avatar
2006FLST
So you guys are saying the deluxe models already have the bolts on them to lower? I am amazed that the factory would not just use these same shocks for all. What would it be....A 20 dollar option LOL
Old Dec 27, 2009 | 02:03 PM
Night_Train's Avatar
Night_Train
It's all fun and games right up till you try to torque the 19mm shoulder screws. The HD manual gives you the part number to purchase what I can only believe to be a very special "crows foot" wrench from Snap-on.
Ray
Old Dec 29, 2009 | 06:06 AM
2006FLST's Avatar
2006FLST
Now I am down to about 1.5 inches. I think I will leave it here. Also tightened the pre-load up. I am diggin it. Here is another worthless crappy picture.
Old Dec 29, 2009 | 12:54 PM
Eltopia's Avatar
Eltopia
My 08 Hertigage classic was lowered by my dealer, who is no longer here. They adjusted my shocks for riding double. Now I want to adjust them for 1 person. I have a spanner wrench and have moved them a little. How much do I move them ? How do you measure the shock preload ?
Thanks
Old Dec 29, 2009 | 02:22 PM
2006FLST's Avatar
2006FLST
Thanks
I am going to assume you loosened the locknut for them. After that they should turn rather easily. Sounds like you want to have a lighter preload. Therefore you need to turn them in or AWAY from the locknut. I don't really know how to measure the preload. I would just adjust a little at a time until I am happy and make sure you turn them in equal amounts.
miketedesco
Dec 5, 2016 06:55 PM
olongapo1
Dec 28, 2011 06:26 PM
strongwood
Jul 27, 2011 11:14 AM
RMBLON
Jun 2, 2008 05:13 PM
dirt_dobber
Jun 15, 2006 12:30 AM
