Shock adjuster question
Old Dec 21, 2009 | 07:56 PM
2006FLST's Avatar
2006FLST
Default Shock adjuster question
Okay got a bonehead question. I have installed shocks before but have never dealt with these lowering kits. Got these stockers on ebay with kits installed for a heck of a deal. BUT in my dumbness what order does everything go on? Meaning how do I adjust and mount up these things. I am assuming I use the one chrome nut to adjust and then mount up (like in my first pic). They are rated to lower the bike up to 2 inches but I guess I just cannot see how that is possible. Anyway pics are attached.
Old Dec 21, 2009 | 09:55 PM
Rockyriver's Avatar
Rockyriver
The longer the shock the more it pushes down on the swingarm. So by installing the longer bolt extensions it extends the shock out pulling the bike down. Does that make sense to you? Get down and look how the soft tail suspension works, and you will see. These kits like yours don't work on Deluxe's like my bike, because they have a longer shock installed from the factory, is my understanding. THe way you have the bushings mounted is correct, just make sure the frame mount is in between the two bushings.
Old Dec 22, 2009 | 05:46 AM
2006FLST's Avatar
2006FLST
Thanks it all makes sense I was just unsure of where to place that extra chrome adjuster nut. I think I got it now. I still don't see how I will be able to lower it much but we will see!
Old Dec 22, 2009 | 02:12 PM
09_NightRider's Avatar
09_NightRider
insted of cranking the chrome nut down towards the shock...
it starts off there(when installing the shock), and you crank it towards the end of the shaft once mounted.
this enlarges the shaft(that didn't come out right), therefor lowering the bike.
when you take your shocks off, take note of how they are mounted, the locktite nut will be tight just so a few threads show.
hope that help clears it up.
chris
Old Dec 22, 2009 | 02:42 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
Taking those stock shocks w/lowering bolts in and out were the biggest pain in the a$$. Those things gave me more of a headache than anything else done on my bike. My airride install was a breeze compaired to them. Make sure to grab a 12 pack.
The longer the lower and the shorter the higher...Good Luck
Old Dec 22, 2009 | 06:06 PM
2006FLST's Avatar
2006FLST
I got it figured out now. You are right though. When I took the shocks out of my last bike (EVO Style) it was the biggest pain in the **** cuss fest I have ever had. I need to mentally prepare myself first.
Old Dec 22, 2009 | 07:47 PM
BLKnCHRME09Deluxe
LOL...Like i said ..Make sure to grab a 12 pack..Thats how i get mentally prepared. Man those were a b*tch.
post them pics when done.
Old Dec 22, 2009 | 09:05 PM
2006FLST's Avatar
2006FLST
Tell me about it. I built my first softail and was able to put the shocks on right after the drivetrain. You could just flip the frame over. Then I had to pull them due to some crappy bushings in the eyelets. I was like WTF!!!! I guess I will try 1.5 inches first on the lowering and go from there. Thanks for the help.
I plan to post picks and have a list of things like possible adding some Nash gimp hangers.
Old Dec 26, 2009 | 10:48 PM
2006FLST's Avatar
2006FLST
Got the shocks on. Right now I am an inch lower but plan to take it to 1.5 inches next week. Wasn't really all that bad. MUCH easier than EVO model shocks like I have done before. Here is a crappy phone pic for now.
Old Dec 27, 2009 | 07:03 AM
BigSeaDaddy's Avatar
BigSeaDaddy
I do not think that is right. I have not done it yet but will. The stock deluxe shocks do come lowered (longer) but you can disable the shocks and put in the longer $20 buck ebay bolt, dropping the bike a full 2.5 inches. Rereading the OP post he bought the shocks with the lowering bolt already installed and only had to mount them up. Were as I am going to compress the springs and swap the bolts until I can afford an air ride.
Now if I am wrong please some tell me now!
