As stated by others Dyno it.If you went and added the stage 1 and pipes looking for more performance you now owe it to yourself to have it Dyno'd for the best map.
Sure its preset map may do the job but its capable of much more.Thats the point of adding a tuner such as the pc3.If all youre planning on doing for engine upgrades are the stage 1 and pipes you would have been much better of simply buying a TFI and saving a few bucks in the process.
TFI ? Im getting pipes and air filter is all i plan to do.. Do i need the PCV OR PC111 ?
If thats all you plan to do dont waste your money on a power commander.A Dobeck TFI is all you need at a fraction of the price.Your bike is already set up to run lean.By increasing the airflow its running very lean.
A unit such as a TFI is plug and play.It alows you to add fuel without requiring a Dyno,you can install it yourself.
Ok haha... should be FIT instead of TFI. i looked at Dobeck and it is $255.00 NO savings there at all.. Well unless you buy a PCV from fuelmoto.. AT HIGH PRICE.. Other WEB Sites sell PCV for less money than The TFI at Dobeck AT and $100.00 Less Than fuelmoto..
