Wide tire kit
Old Feb 9, 2010 | 01:47 PM
Sstuter48's Avatar
Sstuter48
Default Wide tire kit
Hey all I just wanted to know what you all think about a 200mm wide tire on a 99 Night train. I just talked to Ame and he told me I can use my stock swing arm for this if I switch to a chain. Is this true. I was told that it cant fit on my stock swing arm. Just wanted to know what you all think/know.
Thanks Abe
Old Feb 9, 2010 | 02:28 PM
jtmurph00's Avatar
jtmurph00
Yes, you can fit a 200 in your stock 99' swingarm if you go to a chain, but it's gonna be damn tight. I believe Doherty makes a complete kit for it.
You can also fit a 180 in there if you use a 20mm belt. Thats what I did after I saw another member do it since I didnt wanna bother with the hassle of a chain.
Old Feb 9, 2010 | 06:02 PM
Sstuter48's Avatar
Sstuter48
Thanks for the info. Now I need to just figure out the one I want. Again thanks
Old Feb 9, 2010 | 08:24 PM
whoffman's Avatar
whoffman
I will be selling my 200 set-up on my 09 soft tail custom in a couple weeks. Im going with a heartland 250 kit
Old Feb 10, 2010 | 12:27 AM
kiwideuce's Avatar
kiwideuce
i think the problem will be rear fender wont be wide enough,a deuce fender will take a 200 but not a softail, buy woffmans rear fender,or his complete set up! save you having to change to chain with the narrower belt and pulley!
Old Feb 10, 2010 | 09:06 AM
SeMiGoD's Avatar
SeMiGoD
Dont know how much $ your willing to spend on this BUT...heres something to peek at.
http://www.seegercycle.com/softail240widetirekit.aspx
Old Feb 10, 2010 | 01:57 PM
softail99custom's Avatar
softail99custom
My 99 fxstc is in the shop right now getting my new chrome duece wheel installed. The rear fender needed modified to fit the 160/17 Dunlop !! plus the wiring to the lights in the back needed re-routing to make room. There's no way to put a bigger tire than the 160 without going to a different fender. Just my 2 cents.
shovelhead FXEF
Shovelhead
Oct 11, 2012 08:06 PM
Jd Swiper
Aug 28, 2012 03:14 AM
jayjay363
Ironhead
May 28, 2010 06:56 PM
jimsheila
Nov 18, 2007 09:21 AM
jhogan20
Oct 17, 2005 07:26 PM
