Boot Marks
Old Feb 12, 2010 | 06:55 PM
scasey's Avatar
scasey
Default Boot Marks
New to the HD world and I tried this thread in the detailing area but getting no response. Before it happens, how do i remove boot marks from the exhaust or the primary/clutch cover? I installed the new mini floor boards today for the Ol"lady and quickly realized that this will happen at some point and instead of cursing later was wondering if it can be removed.
Old Feb 12, 2010 | 07:34 PM
parttimer's Avatar
parttimer
Any good chrome polish will take scuff marks off. But scratches are another subject.You just about have to live with them. If you try too hard to remove them it will cause the chrome to cloud.
Old Feb 12, 2010 | 07:55 PM
Hooker 6's Avatar
Hooker 6
Boot marks on the exhaust - melted rubber - spray oven cleaner on a cloth(not on the exhaust or the oversppray with spot paint), ride it and rub it off after the exhaust gets hot.
Primary - chrome or metal polish - Mother's ball would work great.
scasey's Avatar
scasey
I guess I need to clarify, not the sctraches, the actually melt on of the black from the boot. I have seen it on many bikes, i have heard WD 40 will remove it but not sure
Old Feb 12, 2010 | 08:00 PM
snook592's Avatar
snook592
ez off oven cleaner
Old Feb 12, 2010 | 08:41 PM
mke125125's Avatar
mke125125
Ive done this several times. just crank the bike and let the pipes get hot,which re-melts the rubber on em. then take a soaking wet rag and wipe it off with quick swipes. it will singe the rag a little depending on how quick you are but it works perfectly.
Old Feb 12, 2010 | 09:22 PM
Quadancer's Avatar
Quadancer
For most plastic rubber sole burns from the wife's boots (several times now), I used solvents, the better being MEK - but have one swipe burned into the pipe it won't touch. I'll have to try the EZ Off cleaner next. The solvents did completely clean the chrome up tho where they worked. Just polish after that.
Old Feb 12, 2010 | 10:31 PM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
I don't know how many times I've said the same thing...
It's just boot poo...it went ON hot, It'll wipe OFF hot...
Some people just want to work hard, I guess...always reminds me of what an old timer kept telling me back in the 60's when I kept trying to complicate things..."It ain't rocket science son...it's a Harley"...
Old Feb 13, 2010 | 12:14 AM
grumpez's Avatar
grumpez
Best thing I have found for this is the cleaner you use on the Glass Top Stoves, takes it right of with the exhaust cold.
Old Feb 13, 2010 | 01:56 AM
Norton88's Avatar
Norton88
So in a nutshell... Cold pipes - oven cleaner then polish
Hot pipes - wipe with damp rag.
I've successfully removed some pretty mean boot goop using both methods
