does not start
Old Feb 14, 2010 | 10:38 AM
grateful_rider's Avatar
grateful_rider
4th Gear
Default does not start
I have and 03 softail heritage. I rode her and then put her up 3 days later I went to start her up got nothing. She turns over, checked the spark with an in line spark plug tester no fire, checked the voltage at the plug going in to the back of coil and resistant oms is 11.8 volts and with 5.56 oms. the hd tech said that the coils hardly ever go out. I did not want to buy another test manual. Any suggestions???
Old Feb 14, 2010 | 10:42 AM
yep's Avatar
yep
Account Suspended
carb'd ? fuel injected? . go thru the simple things an engine needs ... air fuel spark compression ...
Old Feb 14, 2010 | 10:47 AM
grateful_rider
4th Gear
it is carded had compression when I turned it over with out plugs in it you could feel it. no I do not have a gauge,,,
Old Feb 14, 2010 | 10:48 AM
grateful_rider
4th Gear
yes it had gas going in through the carb with over halr a tank of gas
Old Feb 14, 2010 | 10:50 AM
rbabos's Avatar
rbabos
Check crank position sensor. Should be pulsing about 5 volts ac when cranking engine. Check all electrical connections.
Ron
Old Feb 14, 2010 | 11:25 AM
yep's Avatar
yep
Account Suspended
I would go get your self a spark tester from the auto parts store... they are cheap ... start there .. you know you have gas you know you have compression ..
Old Feb 14, 2010 | 11:27 AM
IronAss's Avatar
IronAss
Start with the simplest things first. Kill switch?
Old Feb 14, 2010 | 02:29 PM
grateful_rider
4th Gear
ok here is an update... the crank sensor is about 3 volts dc. taking the starter relay out bike will not turn over. I have compression both cylinder.... Have gas going in to the carb. I have 11.6 volts going in to the coil but no spark???? Kill switch off no turn over, relay out no turn over.... I have an inline spark tester and I also used older spark plugs in the spark plug wires still no spark. Does anyone know what the volts (the other 2 wires) going to the coil should be or do I need a special tester/light fir that too.
jamesparlier
Sep 26, 2016 09:01 AM
Plumbwader
EVO
73
Oct 5, 2015 08:18 PM
Nullum
Shovelhead
Mar 12, 2014 04:17 PM
Cap'n Parrothead
Nov 18, 2012 08:46 AM
LeslieLou53
Exhaust System Topics
Jul 17, 2010 09:57 PM
