95 FLSTC Won't start????
Old Nov 17, 2012 | 05:36 PM
Cap'n Parrothead's Avatar
Cap'n Parrothead
6th Gear
Default 95 FLSTC Won't start????
I just got 95 FLSTC from a deceased relative. I had a 92 FLSTF for several years but it always ran like a top. Never had much work to do on the old one. But this 95 has been sitting for a few months. So far I have replaced the Plugs, Plug Wires, Battery, checked the fuel, oil, and can see fuel going into Carb. She still won't start. Any ideas or helpful info would be greatly appreciated. Thanks!
Old Nov 17, 2012 | 05:47 PM
JohnnyC's Avatar
JohnnyC
I'd check for spark at the plugs. If none check for power at the coil.
Old Nov 17, 2012 | 05:52 PM
Cap'n Parrothead
6th Gear
I got it to spark between the coil and wire but not exactly sure how to check for spark on the plug end.
Old Nov 17, 2012 | 05:55 PM
Tee&Vee's Avatar
Tee&Vee
I would also post this in the Evo section for a more detailed response. There are lots of posts like this.
I would empty the gas tanks first and take off the air cleaner and open the enrichener fully then spray some gum out or Carb cleaner after new gasoline.
Check for spark as mentioned.
Old Nov 17, 2012 | 06:01 PM
Raddazzz's Avatar
Raddazzz
Yeah what he said post in evo forum !
Old Nov 17, 2012 | 09:41 PM
JohnnyC's Avatar
JohnnyC
If you see a spark from the coil wire to the coil odds are it's getting to the new plugs you just put in.
Setting a few months could mean the gas has gone bad in the tank. It'll draw moisture if left over a period of time, especially like winter. Or the gas setting in the carb has gummed it up. You can use an additive in the tank like dry gas, and take the air filter off and spray the carb. Might even want to use some starter fluid carefully.
How did the plugs look that you removed? There's a chart on reading the wear on them to tell how the motor was running.
If it was running good a few months ago it can't be anything major so careful what you tear into. Some guys will start ripping the carb off or attempting to adjust it. It may just be stubborn to start. If you've never seen it being started you just don't know.
Other than that a bike that's been sitting can have seals and gaskets dry out and something as simple as a bad intake seal can keep it from starting.
There are several forums here with Evo having a lot of followers and many great mechanics. Some have been commenting that it may be a better place for the discussion.
I hope to hear you get it running soon.
Old Nov 18, 2012 | 08:46 AM
Cap'n Parrothead
6th Gear
Thanks, for all the help. I will try the things that I can do. Also, did post in the EVO Forum as suggested, got a couple ideas there as well. I am glad that I found this forum, only a couple days and great help and info are great. Keep you all posted and I am sure I will need more help as I go along. Thanks again to all!
AFORAL
Nov 19, 2018 09:25 PM
RidemyEVO
Jan 7, 2016 03:33 AM
npsocal
Carburetor Related
Aug 11, 2015 05:26 PM
Pissdrunktbone66
Exhaust System Topics
Oct 4, 2012 06:09 PM
petewood70
EVO
19
Jul 1, 2010 06:55 PM
