Question about stock wire harness routing
94 FXSTC is the year/model.
I need to know if the stock from wire harness goes under the seat pan (putting it very, very close to the rear rocker cover) or over the seat pan (under the actual seat.)
I just got done disconnecting a bunch of **** to get everything under the seat pan and realized that puts the main harness basically right on the rocker cover! Is that the factory routing?
as usual, thanks in advance.
boy...a year ago I couldn't do much more than change my oil, now I'm ripping wiring out and re-running it! Heh.
I need to know if the main wiring goes OVER the area where the seat goes (under the seat) or under that area (over the rocker box.)
You can see it if I route it the latter way...I don't think the intent was to be able to see the wiring, but the battery area is much neater that way.
I know this is kinda a dumb question...just hoping someone would come along
