Ape hanger install
Old Feb 28, 2010 | 07:39 AM
Maddog77's Avatar
Maddog77
Stage III
Default Ape hanger install
A little help. I'm just about fnished with my install of a pair of 18" HCC apes on an 08 Heritage. I saw a thread about what riser to use "because I know the stock risers won't work".
I'm using the stock risers and don't "see" any problem at this point. Do I have a rude awakening coming? Why won't the stock risers work?
BTW....doesn't there have to be a better way to route the switch control wiring in the switch covers.....what a PITA!
Old Feb 28, 2010 | 07:42 AM
sBender's Avatar
sBender
Stock risers should be fine. The only time Heritage risers wont work is if your bars are 1 1/4 (or 1 1/2) all the way through (not reduced to 1" at the riser). In fact, I'm using stock Heritage risers on my train.
Post some pics, bro.
Old Feb 28, 2010 | 07:43 AM
handyhoward's Avatar
handyhoward
When you turn your bars side to side do they hit the tank?
Old Feb 28, 2010 | 07:48 AM
Ballsout's Avatar
Ballsout
Most of the time when ppl say that the stock risers wont work are when they are referring to Fat Boy bars and risers. Fat Boys (newer) use 1.25" bars all the way through with no reduction at the riser. So the risers for those bars are 1.25. The HCC bars reduce to 1" at the riser so you would need new risers that are 1" dia, as I did. I used wild ones 535 and 525 clamps. Hope that Helps and Welcome aboard!
Old Feb 28, 2010 | 07:50 AM
Maddog77's Avatar
Maddog77
Stage III
I haven't put the tank back on yet so can't answer that....don't see why they would but may mock up this am just to check. Thanks
Old Feb 28, 2010 | 07:57 AM
Ballsout's Avatar
Ballsout
Have never heard of this problem with apes on a Heritage
Old Feb 28, 2010 | 10:07 AM
MoonCricket's Avatar
MoonCricket
consider changing out the stock bushings to some nice polly ones
Old Feb 28, 2010 | 10:11 AM
murlsquirl's Avatar
murlsquirl
They will work. The HCC bars are 1 1/4" and tapered down to 1" for the controls and riser area. I have the stock top clamp on mine. Like someone else said, get some hard poly bushings.
gnstalodz
Dec 17, 2012 06:05 AM
atretes1
Dec 22, 2011 01:55 PM
glideridemike
Aug 5, 2009 08:44 AM
Kdavid
Jun 26, 2009 10:16 PM
Unibomber
Jun 25, 2006 08:06 PM
