Rocker
Old Mar 3, 2010 | 12:21 PM
gadawgsfan's Avatar
gadawgsfan
Default Rocker tag bracket
i know several of you rocker owners have mounted your tags on the bolt that holds the upper belt belt guard cover on to the swing arm.
can anybody tell me where to buy this same set up?
thanks
Old Mar 3, 2010 | 12:38 PM
rubiconMike's Avatar
rubiconMike
I bought mine about 1.5 yrs ago off of ebay. I've tried to find the seller to forward on to other people in the past but can no longer find him. Sorry, I'm of no help.
Old Mar 4, 2010 | 12:36 PM
gadawgsfan's Avatar
gadawgsfan
thanks anyway mike, i think that is the one im looking for, it was on ebay. guess i should have bought it then
Old Mar 4, 2010 | 07:42 PM
bikermike2's Avatar
bikermike2
hey gadawgsfan. i did just that made my own bracket just bent some metal 1/8 thick. one of our brother warned me someone mite hit it & brake it. well that did not happen .what did happen is the wind on the hwy. it bend back & broke off not only that it broke the bracket from the frame to the chain Gard. real bummer . should have listen. the only good thing is i can take the bracket off the frame & weld it . its just on with 2 sided sticky tape. witch freaks me out that its just on with sticky foam tape. now i have mounted it to the rear foot peg & metal bracket is 1/4 " thick. if you can make a bracket .here's the tag with running tag & brake light. before it broke. hope this helps you out brother.
Old Mar 4, 2010 | 10:05 PM
m i k e's Avatar
m i k e
i gat kuryykn
heartland makes 1 too
Old Mar 5, 2010 | 03:20 AM
kiwideuce's Avatar
kiwideuce
im after a side mount too!
Old Mar 5, 2010 | 09:01 AM
Rail's Avatar
Rail
I highly recommend you don't mount the tag on the upper belt guard if you want to keep the guards on.. I had moine mounted there for about 6 months and then some dumbass decided to smack it walking by and busted it off.. Zip tied it to get it home then had to figure somethign else out.. What I did was buy the 1.25" and 1.5" swing-arm clamps from Drag.. They're actually 2 piece.. Then I beat and banged until I got the 1.25" egg shaped to fit the Rocker swing-arm, painted it and mounted my side mount plate bracket.. Took about an hour to do and was a lot cheaper than $200+.. I think the Drag brackets were like $6 and for a Yamaha swing arm.. lol
Old Mar 5, 2010 | 09:59 AM
gadawgsfan's Avatar
gadawgsfan
thanks for the input everyone, i saw one for the rocker that someone is making that looked nice it was something roto i trhink but i believe it was around 250 - 300 dollars, just seems aweful high to mount and hold a tag, ill come up with something
thanks again
Old Mar 5, 2010 | 12:49 PM
swinger27's Avatar
swinger27
Jp Cycles you can get the swingarm set up for around 150 I think it is. The bracket is somewere around the 40-50 dollar range for the swingarm. Just a clamp that is made of for the rocker swingarm by kuryakan. Kuryakan also has a plane jane plate. Heres what the end result looks like.
Old Mar 5, 2010 | 12:56 PM
swinger27's Avatar
swinger27
see if this worked sorry guys still figuring out the adding pics thing
