floating disc rotor
Old Mar 7, 2010 | 05:34 PM
HD2005springer's Avatar
HD2005springer
Default floating disc rotor
Hello..
What is the difference between a floating rotor and a regular rotor.. other than the price tag??
Can they be interchanged with out changing calipers?
Old Mar 7, 2010 | 05:57 PM
Mr. Lucky's Avatar
Mr. Lucky
Floating rotors are always 2-piece, and typically the center is lightweight aluminum. Regular rotars are usually 1-piece and weigh more. Full floating rotors are secured with special hardware which allows the pieces to "float" slightly in response to the different heat expansion characteristics of the two metals:
There are also semi-floating rotors. They are primarily for looks and weight savings. They can all be interchanged.
Old Mar 7, 2010 | 08:48 PM
klf33's Avatar
klf33
From your end, you will not notice a difference.
I have them because I bought them off someone and they were black centers which is just looks.
The technology is good because the outer material is made of a different material than the center, idea is, the outer material can take extended amount of heat, while center is designed for connecting the rotors to the wheel.
This amount of heat is required by 'Racers' they hit the breaks so hard at every corners, usually 18 corners per lap, in 20 laps, so they need to handle 360 breaks from 180MPH down in a span of 24 minutes
My guess nobody on a cruiser or even a street bike will ever need this, so no difference at all.
Old Mar 7, 2010 | 08:59 PM
nighttrain72970's Avatar
nighttrain72970
You don't have to change calipers. I put one on the front brake of my night train.
Old Mar 8, 2010 | 06:42 AM
HD2005springer
Thanks for the info....
Figstr
Jan 5, 2010 11:08 AM
harleyheaven
Sep 28, 2009 07:11 AM
Hog Yild
Apr 23, 2009 08:32 PM
Opossum
Oct 5, 2007 09:30 AM
SIM
Jul 30, 2007 06:14 PM
