Aloha, I thought I was done after I changed out the old Main circuit breaker but I couldn't get it to run. So I ran the diagnostic and I came up with the codes of (P1351 and P1354) which states that the front and rear Coil driver
is open/low. Now can anyone tell me what needs to be replaced? The coil or the ignition module? Just for FYI I own a 06 softail standard, carb.
Sure, What I did is ran the diagnostic sequence on the Dash, there is a sticky I found that shows how to do this on this site somewhere. It works really well
and can be done any time to find what might be wrong with the bike.
OK! I got the location, go back to the main forum and look for the Do It Yourself Section,
then go to the Testing ECM Codes (04-06) thread and youwill see how to do it yourself.
Hope you find this helpful.
