Running Problems
Old Mar 23, 2010 | 02:21 PM
hawaiian Dragon's Avatar
hawaiian Dragon
Default Running Problems
Aloha All, Just an update to a Problem that was hard to diagnose. My bike(an 06 softail standard) started to miss and die while I was on a Sunday Ride.
Symptoms: Stalling, dying (as if out of Gas),and Surging. I checked the fuel and lines, all good, Did a Diagnostic check and came up with the codes: 1351, and 1354, both coil codes of either low or no spark. Did the logical thing and replaced the Coil. No help! The codes cleared up but no fix. I was told that the MAP module is bad because it controls the advance curve in the carb models. changed it out, not the issue.
I bought the Dynatek module for my model and it Fired right up, and runs great. So if you should have the same problem find a friend that has the same year as yours and swap out the module and see if that solves your problem, I don't have anyone that has the same model so I lost a few bucks in search of my fix. Hope this helps some of you. I guess there's no code for a failed Ignition Module.
Old Mar 23, 2010 | 03:01 PM
ao2slabaugh's Avatar
ao2slabaugh
thanks for the heads up
dog155
EVO
Aug 8, 2017 08:35 PM
bigben46
Jun 15, 2015 11:06 PM
french harley lover
Mar 23, 2012 11:32 AM
hawaiian Dragon
Mar 8, 2010 06:54 AM
rsherrow37
Aug 27, 2007 01:00 PM
