I'm done with the mods took all day but hears the break down...
Started with the new rotors... stainless bolts for the pulley didn't fit so my friend Tony ran down to get new ones at the dealer. Thanks Tony couldn't get it done today with out your help... Front fender is on again but was to tired to take pictures...
So the bolts in the kit that worked was the rotors bolts only
Then I dug into the tubes and trees... Oh and the back got some new rubber (Thanks Chuck)
Also changed out the stem bearings while i was around there... figured may as well...
My bike with beach bars... Not...
Okay mod time... 2 under tubes... (Thanks Mike) also a drop in Progressive lowering kit cut the PVC down to 3.25 inches...
So in all the frontend has 3* rake, 2" under tubes and 2" drop in kit... and a Sunday lost...
