V&H BigShots-Adding Baffels??
Old Aug 4, 2006 | 12:52 AM
softail2005's Avatar
softail2005
Default V&H BigShots-Adding Baffels??
If you add the baffels after you have set up your V&H Fuelpak or other Fuel/Air device do you have to readjust the management device for the additional backpressure??
I set up the Fuelpak myself after installing the V&H BigShot Staggered Pipes. The Fuelpak is easy to set. You just set 18 modes with data from their chart. Does anyone have experience with changes that they were required to make following the later installation of baffels?
I assume you have to do this but want to check with folks who have made the changes.
Lee
Old Aug 5, 2006 | 08:37 PM
sfcmo357's Avatar
sfcmo357
Default RE: V&H BigShots-Adding Baffels??
?? Had mine done all at once. I hope someone responds with the answer u need
Old Aug 5, 2006 | 09:07 PM
Bikermike's Avatar
Bikermike
Softail2005 is that a corbin seat on youre bike?
Thanks
Old Aug 6, 2006 | 10:40 AM
GPLRJBRAZIL's Avatar
GPLRJBRAZIL
Yes you have to load a different setup. Mine has setup FP-0011 for stock baffles and FP-0002 for quiet baffles. I use the second one with a few mods sent by a V&H technician and works wonderful. The mods are mode 1:5 and mode 5:7. This was due to some gags when changing gears.
DaSham58
May 8, 2013 01:14 PM
Dragochop
Jan 24, 2013 08:55 PM
rdondes
Apr 9, 2009 11:10 AM
mtrout
Exhaust System Topics
Jul 27, 2006 01:02 AM
StreetBob
May 2, 2006 02:10 PM
