Starter Replacement
Old Mar 29, 2010 | 01:00 PM
deluxenut's Avatar
deluxenut
You'll need a AC/fuel line quick disconnect tool. The specific size is 3/8", but you'll probably have to buy the complete set which is not a bad deal. Sears has a Lisle set here: http://www.sears.com/shc/s/search_10...isconnect+tool
A shop manual would be a good investment if don't already have one. It will show the procedure.
As far as prices on starter's or what brand to buy, Google is your best friend or do a search in this forum.
Old Mar 30, 2010 | 01:36 AM
kiwideuce's Avatar
kiwideuce
not battery is it? my mates bike would start, go for ride turn it off.it wouldnt start while warm, turned out to be battery!
Old Mar 30, 2010 | 02:53 PM
Figstr's Avatar
Figstr
I have a new battery which is kept on a tender all the time when the bike isn't ridden.
UPDATE: I finally got my PC in the mail and put it on last night. It didn't solve the problem. My buddy, who stopped by to say hi and wound up helping me (God bless him), noticed smoke coming from the AC right after I shut it down for another try. It hissed and then he saw smoke. I myself have noticed this a few times over the past few months since I've had this problem.
Anyone with ideas why the smoke from the AC when I try to start it?
Old Mar 30, 2010 | 06:50 PM
kaynine840's Avatar
kaynine840
you dont need a special tool to disconnect the oil lines. it makes it easier, but its not that hard to do without it. at the top of oil line where it connects to the reservoir, just pry of the chrome covers with a small flat screw driver. (they arent on there that tight and you can do it without scratching the surface). underneath the chrome caps are plastic clips that you squeeze and pull. the oil line should come right out.
Old Mar 30, 2010 | 06:54 PM
kaynine840's Avatar
kaynine840
oh, and theres no such thing as a bad starter. just a couple internal components that can be rebuilt or replaced for cheap. for mine, it was the starter clutch.
Old Jun 8, 2010 | 07:01 PM
DutchBiker's Avatar
DutchBiker
Stage II
I'd have to agree with whoever said your groung on your starter might be the problem. ECM problems WILL NOT contribute to hard starting,unless the ecm is not delivering fuel at all. Now MAYBE the stealership didn't tighten something that may have contributed to the starter problem but unlikely. There is a ground wire attached to one of your mounting bolts on the starter......start looking there. If it's not that,it sounds most like a starter clutch or starter selenoid problem.
Old Jun 8, 2010 | 07:26 PM
soft 02's Avatar
soft 02
kaynine840 is right you dont need a tool just squeese the black oil line keepers and pull the lines out after you pull the crome covers back and he is also right about the starter. I have torn mine down three times. Twice for the over run clutch and once to file the contact points on the solinoid contact plate. The 1.4 kw starters are a realy good unit. If its the over run clutch i recomend not getting the harley one but the lifetime warrenty one is a great unit. And yes their name is lifetime warrenty I think.
Old Jul 24, 2011 | 04:14 PM
Roadglide2006's Avatar
Roadglide2006
Stage III
Default Same Problem
I am in the process of removing my starter and I have a question.I can pull the the starter 1" out but it won't come out..Am I supposed to remove primary cover and tap it out from the primary side .
Old Jul 24, 2011 | 04:18 PM
soft 02's Avatar
soft 02
I think on the pre 07's had a bolt inside the primary. 07's are held in by 2 bolts and friction of the o-ring plus the 2 wires. Hope others chime in. RG's might be different. And welcome to the forum!
Old Jul 25, 2011 | 07:47 AM
kaynine840's Avatar
kaynine840
mine is an 06 and i had to pull the primary cover off to remove a bolt from that side. it is a long skinny bolt and do not over torque it when putting it back in cause it snaps very easily.
