rocker rear axle
Old Apr 1, 2010 | 08:53 AM
DragonSlayer08's Avatar
DragonSlayer08
I have the 24 piece VIM Tools Hex Master Set:
13-pc Metric hex 2mm thru 19mm.
13-pc SAE fractional hex 3/32" thru 3/4".
S2 steel drive bits in knurled chrome holders.
1/4", 3/8" and 1/2" square drives.
Plastic storage case.
Lifetime warranty.
S2 steel, the strongest hardest drivers available
I use it all the time and is well worth the money.
In regard to the axel mount plat I agree with rail, Top-Down Products makes the best one out there and the customer service is second to none.
Old Apr 1, 2010 | 10:41 AM
ao2slabaugh's Avatar
ao2slabaugh
Originally Posted by Rail
TopDown Products has the best axle side mount I've seen.. The recess on the rocker swingarm makes it hard for a standard axle mount to work properly..
that's my problem i was wondering about the recess and how the fit would be i bought one not thinking now i gota find out how to make it work
Old Apr 1, 2010 | 10:52 AM
ao2slabaugh
any ideas? i thought about bolting it to the bolt the swing arm is attached to
Old Apr 1, 2010 | 02:12 PM
Dennis@TopDownProducts's Avatar
Former Sponsor
We do offer just the Axle Nut Kit as an accessory. It comes with a new axle nut, adapter hub and 1/2" button head/washer hardware. This would let you mount your side mount off the axle using the 1/2" bolt, assuming you have at least a 1/2+ hole in the side mount. The link is below.
Top Down Products Accessories
Dennis
Top Down Products
Dennis.Sauro@topdownproducts.com
www.topdownproducts.com
Old Apr 1, 2010 | 02:16 PM
Rail's Avatar
Rail
Dennis
Top Down Products
Got one of the nuts and it's slick.. When I decide to move my side mount back 'll be using it..
Old Apr 1, 2010 | 02:53 PM
TENN C Rocker's Avatar
TENN C Rocker
Default Roto plate
I have the Roto plate with the Axle Kit. Got it from Top Down. Works great!! Easy to install. You have to hide the wire, but thats not a problem.
Old Apr 1, 2010 | 04:45 PM
ao2slabaugh
thanks got the axle nut kit next question i pulled off the rear fender and wow all i gota say that wiring harness is almost all internal under the fender so how did you rerun your wire to the plate?
Old Apr 1, 2010 | 04:58 PM
ao2slabaugh
thank god for the navy tool room found a 3/4 allen gotta love the military lol
Old Apr 1, 2010 | 06:19 PM
ThunderRock63's Avatar
ThunderRock63
If you have a 5/8 sparkplug socket,the hex side of it fits perfectly. put your extension thru the socket side, instant rear axle tool.
Old Apr 1, 2010 | 07:05 PM
Joe What's Avatar
Joe What
If its a side mount plate? Find the wire before it goes into the fender then re-route (splice it or cut at the current posiition and pull it out) it by the swing arm to the plate many ways to secure it at various points where it wont be visible...
