cutting a windshield
Old Apr 6, 2010 | 06:38 PM
Dorkman's Avatar
Dorkman
Here is a link to a good how to. Worked for me...just go slow and careful.
http://www.motorcyclecruiser.com/tec...eld/index.html
Old Apr 6, 2010 | 06:49 PM
Hocus-Pocus's Avatar
Hocus-Pocus
Originally Posted by dragpipe
hey guys...
a neighbor of mine wants me to cut her windshield down about 5 inches smaller in the height.
i suggested she just buy another shield, and sell this one but...its her call.
i have a table mount scroll saw, bench grinder, buffing wheel...ect.
my question is: will it crack????
i am under the assumption its made of lexan. i plan on taping the cut line with electrical tape, and slowly cutting it on my scroll saw. then deburr and buff the edges to match whats already there.
has anyone done this before and how'd it go?
she knows im not held reliable if it cracks or breaks, as im not charging her.
i appreciate all yer responses!
thanks.
First off, don't use elec tape...use masking tape. Use a jig saw with fine blade. After you deburr it and remove the tape, use a propane torch and go over the edge and it will smooth it out
Disclamer added: use this method at your own risk
Old Apr 6, 2010 | 08:22 PM
dennyo's Avatar
dennyo
I Posted some PICs of cutting my Lexon Windvest down 2 in.
just take it Slow
https://www.hdforums.com/forum/gener...-windvest.html
Old Apr 6, 2010 | 10:28 PM
SoftailDon's Avatar
SoftailDon
I followed this link and cut mine down.
Only thing I did differently id run a cotton ball that is DAMP with acetone over the edge.
That makes it look great. Do not get any acetone on an anything but the very edge.
http://www.youtube.com/watch?v=hQj05...x=0&playnext=1
Old Apr 6, 2010 | 11:00 PM
oct1949's Avatar
oct1949
I used a roto-zip to take off 4"" last yr, it cut the shield very easy, tape it off both sides, lay-out the cut line..
make a pass to practice on in the area to be thrown away... as the cutter will want to pull toward the opposite direction of the blade rotation.
Hold the cutter firm and go easy,,, after cutting file the edges with the tape still on the prevent scratches.
Old Apr 7, 2010 | 12:44 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Did the same with great success. Using a hand held belt sander helps to smooth out any imperfections in the cut. The Acetone seems like a great idea also.
good luck!
Old Apr 7, 2010 | 01:06 AM
Sancho's Avatar
Sancho
I use my 9" band saw. File the edge then sandpaper. I haven't broken one yet.
Old Apr 7, 2010 | 06:31 AM
dragpipe's Avatar
dragpipe
thanks alot guys! theres alot of usefull info here. thanks for all the links too. i watched them all, and now im very confident i'll do a good job.
thanks guys!
yer the best.
Old Apr 7, 2010 | 08:53 AM
PPBART's Avatar
PPBART
Originally Posted by ctbird53
I used a jig saw with fine tooth blade & finish sanded the edge with a belt sander...do a search on cutting a windshield & theres alot of info on this
+1 -- I did the same, took about 4" off the windshield on my FLSTN, looks just as good as any glass shop would do. Overall, I probably spent a couple of hours on it, didn't get in any hurry.
Old Apr 7, 2010 | 09:44 AM
sp9997's Avatar
sp9997
Originally Posted by wyndnface
Check this site out on how to cut a windshield.
My bud did this process on his fatboy windshield, but he only took a couple of inches off.
When he was done it looked 99%. He had one little booboo ,You know the one where only you can see it!
Teamster
+1 on this. I did it to my fatboy king windshield..was too tall for me I am only 5'4" so had to cut it down.. follow this down to the T and you would have no issues at all.. worked for me should work for you as well..
