shift linkage sticking.....Help!
Old Apr 7, 2010 | 05:42 PM
mike06train's Avatar
mike06train
Default shift linkage sticking.....Help!
So, I rode to work the other day and it started to rain when it was parked in the lot. I ran outside and put it in the warehouse and dried it off. Today the shifter will shift but I have to help it to come back to center. I sprayed the linkage with WD40 incase some rust was holding it up but no luck. Any ideas?
Old Apr 7, 2010 | 06:00 PM
Tom84FXST's Avatar
Tom84FXST
http://www.*****************/forums/tw...nkage-fix.html
Old Apr 7, 2010 | 07:39 PM
mke125125's Avatar
mke125125
get some rem-oil from wal-mart. it is a synthetic gun lube that comes in a can like wd-40 with the little tube. spray it in the pivot shaft where the shifter mounts and work it in real good. no more sticky shifter. unless you have a bigger problem than dirt and corrosion.
Old Apr 7, 2010 | 09:45 PM
rickb's Avatar
rickb
Yeah take it a part clean it up and lube it have had good luck with grafight (spelling???)dry lube.
Old Apr 8, 2010 | 02:24 PM
story808's Avatar
story808
rickB... is right take it apart clean and lube it up... It's gunked up in there and sprays like wd40 may help temp. but you gotta clean out the old gummed up grease and lube it. You'll be much happier then a quick fix. It's real easy first time it'll take you about 10 to 15 min.
mind the plastic bushing and how it came apart.
cwsharp
Aug 22, 2022 11:54 PM
chkywuky
Sep 25, 2013 07:33 PM
busch
Aug 15, 2009 06:20 PM
Figstr
Sep 3, 2008 05:59 AM
XRP
Aug 21, 2007 09:58 PM
