Shifter Linkage
Old Sep 24, 2013 | 08:31 PM
chkywuky's Avatar
chkywuky
6th Gear
Default Shifter Linkage
Have any of you guys mounted the front shifter linkage to the inside of the front linkage arm.I did and I like it.It's a straight shot to the back arm versus angled in when mounting on the outside of the front arm.It tucks in closer to the motor also
Attached Thumbnails Shifter Linkage-img_0017.jpg   Shifter Linkage-img_0011.jpg
Old Sep 24, 2013 | 08:53 PM
HDmikie's Avatar
HDmikie
Sooooo, what's your question? We all have shift linkages.
Old Sep 24, 2013 | 09:12 PM
Ragnar's Avatar
Ragnar
As long as there is clearance, it'll work fine. Neat linkage rod.
Old Sep 24, 2013 | 09:21 PM
GonzoTx's Avatar
GonzoTx
Every Harley I've owned came with the linkage mounted on the inside ...
Old Sep 24, 2013 | 10:18 PM
chkywuky's Avatar
chkywuky
6th Gear
Are there any negatives on swapping the Front of the linkage rod from the left side[stock] to the right side of the arm where mine is now.Both my 01EG and my 13 RG both have the front mounted on the left side. I did have to adj. the rod a little longer so it missed the cyl. fins.It seems to work better than stock.
Old Sep 25, 2013 | 07:47 AM
HDmikie's Avatar
HDmikie
I'm trying to understand why you would want to move the linkage rod. Anyways, just so you have clearance, I see no problem swapping from left to right.
Old Sep 25, 2013 | 06:07 PM
hdbob2006's Avatar
hdbob2006
If it was on the outside originally,it was wrong. Now you have it right..
Old Sep 25, 2013 | 07:33 PM
deadman77's Avatar
deadman77
Nice job, thats where it goes.
hyrax222
May 24, 2016 09:47 PM
c50plus
Dec 16, 2011 12:36 PM
RadarRider
Jul 6, 2011 08:16 AM
Wireguided
Shovelhead
Jun 18, 2008 05:39 PM
XRP
Aug 21, 2007 09:58 PM
