Calling all FatBoy Lo Owners
Old Aug 9, 2011 | 04:10 PM
  #3711
abnchiefcw3's Avatar
abnchiefcw3
I can understand apparel being made overseas but I thought ALL Harley parts were made in the US. Wrong. I bought the Harley floating rotors for my bike and right on the front of the rotors it says Made in Japan.
Old Aug 9, 2011 | 04:22 PM
  #3712
Sgt_Jim's Avatar
Sgt_Jim
Look on the inside of your forks sometime, down near the axles.. they're Showa forks, made in Japan
Old Aug 9, 2011 | 04:43 PM
  #3713
Misbehaven's Avatar
Misbehaven
They have been using the Showa forks since the AMF days.
Old Aug 9, 2011 | 04:53 PM
  #3714
Sgt_Jim's Avatar
Sgt_Jim
yeah, point is, they're not made in the USA..that's all happyface.
Old Aug 9, 2011 | 05:50 PM
  #3715
Zombiequest's Avatar
Zombiequest
the bolts aren't that long, keep in mind they have to reach through the mount, a rubber piece which is like 1/4" thick at least, the fender itself, and be able to be threaded into the nut..idk how much space you have between your tire and fender, but i have more than enough to fit my entire hand up there to hold the nut still while i get the bolt threaded before i wrench it down..
I discovered that the hard way.. tried to do it inside out first and although the bolts are short, it was actually TOO long for that because they stuck up higher then the plate surface and would be impossible to put the frame on without bending the crap out of the Plate itself.
So outside-in was actually the only means with these bolts... My hands aren't TOO big, but I had an absolute BEAR of a time keeping a wrench in place under there or even unscrewing the original bolts... so I rummaged through my toolbox and found this sucker.
This message sponsored by... HUSKY... without this tool the Stress would easily take a good 20 years off your life... Husky, keeping you sane since 1924.
I swear, this little bastard tool was an absolute "Lifesaver"... sucker took about 5 minutes to install when it would've taken me about an hour or 80 to 90 wrench-drops later. Without it, this modification would've killed my "inner child".
Old Aug 9, 2011 | 05:57 PM
  #3716
Reaper19's Avatar
Reaper19
6th Gear
Hey Law whats the chance of you taking a closer picture of those bags and the fillers you put in just want to see how you did that.
Old Aug 9, 2011 | 06:26 PM
  #3717
Sgt_Jim's Avatar
Sgt_Jim
Yo Zombie.. can you take some more pictures of those turn signal lenses? I'm thinking about getting the visored ones with the smoked lenses (front and rear) to match my headlight trim.. can you take some pictures from the rear/sides/etc please?
Old Aug 9, 2011 | 07:49 PM
  #3718
Zombiequest
Here's a few... it was getting dark here when I took them so these pics probably wouldn't win any awards.. that car cover behind him his covering my '73 Triumph Spitfire.. Black Jeep Wrangler, Black Spitfire... odds were I wasn't going to get a white Harley.
Got the Headlight ring on yesterday, License plate today.. seems like every day a new mod arrives in the mail. The turn signal bulbs are orange, instead of the lenses.. these aren't smoked.
Old Aug 9, 2011 | 07:52 PM
  #3719
harleyfiremedic's Avatar
harleyfiremedic
Hope you don't mind, but since I have a pic of the visor turn signals, thought I would show them off
Old Aug 9, 2011 | 07:59 PM
  #3720
Zombiequest
They are very cool... that was one of the first things I put on my list months ago when I wrote out all the mods I wanted.
Beyond easy to swap out also... probably the easiest mod there is.
