Do I need another map?
Old Apr 11, 2010 | 06:41 AM
Dieselhed's Avatar
Dieselhed
Default Do I need another map?
Forgive me if I've posted in the wrong section but I thought I'd get more exposure here. Did alot of mods this winter, but the only motor related were going from V&H staggered straight shots to V&H Big Radius and ditching the football AC cover for a Jersey Customs football cover with the ends cut off and holes added. Same SE air cleaner, hell I didn't even remove it. Now on about every other cold start up I've got a slight backfire which sounds like it's coming from the exhaust. Hit the starter button, pop. Wait a sec, hit it again, fires right up. Runs normal. Doesn't do it when warm.
Pipes have Big City Thunder Monster Baffles. Bike has PC III usb. I've also got a little rust colored spot on the front pipe right before the heat shield. Not blue. Any thoughts?
From this........
To this...........
Old Apr 11, 2010 | 07:22 AM
coop57's Avatar
coop57
What year is your deuce?
Stock ECM or stage one?
Old Apr 11, 2010 | 07:34 AM
coop57's Avatar
coop57
Map M805-148
2004 Softail
V&H Big Radius Drag Pipes (A402R Baffles)
Screaming Eagle air filter
Stock ECM
This may be the one you need.
Old Apr 11, 2010 | 08:21 AM
Dieselhed's Avatar
Dieselhed
I bought the bike like you see it in the first pic. Already had the 103" kit installed. I do have all service records and receipts though and from looking at the dyno sheet after install it says "stroker ecm". I have fuel and ignition table copies as well. It also says "ECM CAL #32945-02,USB PC. And has the previous owners name and 805 ADV. MAP after it. This was from 1/5/07. The engine was built in Dec. of '02 so not sure what he was running up to the 1/5/07 date.
Old Apr 11, 2010 | 08:22 AM
Dieselhed's Avatar
Dieselhed
The bike is an '02.
Old Apr 11, 2010 | 08:43 AM
mike06train's Avatar
mike06train
Man that sounds like alot of unknowns. If it was me it woud be time for the dyno.
For around $300 you would know it was tuned perfect.
Old Apr 11, 2010 | 08:46 AM
Dieselhed's Avatar
Dieselhed
That's my problem. I'm in the Kansas City area and I just don't trust the dealer to do it.
Old Apr 11, 2010 | 09:06 AM
coop57's Avatar
coop57
Sounds like dyno time, power comander.com has a list of authouized centers I am sure you can find someone of good reputation in the KC area.
Good luck.
Old Apr 11, 2010 | 11:26 AM
Dieselhed's Avatar
Dieselhed
Yup. Just found one. Not too far either. Gonna make an appointment. Any idea how much I can expect to pay?
Old Apr 11, 2010 | 06:12 PM
coop57's Avatar
coop57
I've heard to expect 300 bills I was quoted 500 but I found a map for my set up.
Let me know what your damages are.
