Thunderbike Rockers
Seriously my friend has Wariorr and realy like this bike and that gas tank is just some brutal
Of course i would never left my HD.....I asked the guy who make the gas tanks for Thunderbike, if he can make for me custom gas tank which will be big and wide using Thunderbike fuel pump,etc... now waiting for answer.
Buy a replacement tanks from HD. I bought one for $405.00 deliver. It is primered and ready for paint. Then you could buy from RSD thier "Gas-It" Fuel Injection Kit.
HD Stock Componets + RSD Gas-It Kit = Ready to Ride
And modify the tank to make it work. Here is how it looks on a smaller tank.
Here is thier ad for it and what it said.
QUICK... STASH IT INSIDE THE TANK!
Building a custom tank for your fuel injected Harley? Wondering
how to cram all that fuel injection equipment into the tank? With
the RSD Gas-It Kit, your stock HD fuel injection parts are removed
and relocated inside the tank, allowing a clean, uncluttered tank
face, while maintaining the fuel injection we all love so much.
FEATURES:
Relocates OEM 01-07 Delphi Fuel Pump, Fuel Pressure Regulator, Fuel Filter
& Fuel Level Sending Unit To The Underside Of Your Custom Tank
A Smooth And Reliable Way To Hide All Fuel Injection Components
Includes Billet Machined Steel Weld-In Plate, 3.75 X 8 Aluminum Manifold,
Installation Instructions & All Hardware Included
Same Kit That Is Included With RSD Fuel-Injected Vintage Gas Tank Kits
Requires Vented Tank Or Vented Gas Cap
*Custom fabrication and welding required
*Your custom tanks bottom must be relatively flat to accommodate port installation
*Not legal for sale or use on pollution controlled vehicles
Here is the info to order it is you are interested
PRODUCT DESCRIPTION = Gas-It Fuel Injection Kit
PART # = 1022-0046
SUG. RETAIL = $425.95
I hope this helps you out.
Some gas tanks have exact size of cutout in bottom to fit RSD or it must be fabricated ? I was thinking to put it on stock Rocker gas tank but there is no space.
You say replacement tank from HD - which one without dash and only one gas cap for Rocker? I was not able to find any (even searching aftermarlet) to fit latest softail. All of them says till 1999.
So if i take some 99 softail gas tank and put it together with RSD kit (question is how), will this fit Rocker?
Considering all these questions i started to think about that Thunderbike solution which is exactly for Rocker. Just the tank shape is not what want.....
I am just realy upset now because i started too late with this, spring is here and i am wasting time, can not ride........ I should start sooner or wait till next winter
WOW that is the tank to go with. Now that is the look I have been trying to get myself. I have been trying to figure out how to clean the tank and get rid of the console. I plan on using Dakota like yourself. If you go this route or and info on that tank I would greatly appreciate. Next winter is when I had planned on doing mine. Thanks and keep us informed.
