How do I replace Softail shocks???
Old Aug 8, 2006 | 08:31 PM
WV_Bowhunter's Avatar
WV_Bowhunter
Stage III
Default How do I replace Softail shocks???
Well, my '98 FLSTC needs its shocks replaced; my Softail is now a hardtail. I found Progressive 413's at a great price and picked-up a set. While waiting for them to arrive, I decided to pull the stockers off and that is my problem. I'm able to get the bolts to turn (slightly) but they have great resistance all the way around. I don’t have a lot of space, so its really hard to turn with stubby wrenches and a pry-bar. Are they just dipped in loktite? -or- am I doing something wrong?
Please shed some light on this!
Thanks,
Chris
Old Aug 8, 2006 | 10:43 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: How do I replace Softail shocks???
You don't own a manual do you?
You need a few different wrenches, as well as a screw jack with a platform as well as another jack for the bike.....
The biggest PITA is the mounts to the swingarm, as I use an aircraft grade torque adapter (Spline) to break loose those bolts....
The shock mounts at the frame are another story, as you need to hold the shaft between the shock body and frame, then loosen the nuts on the ends.....
Have Fun.....
Old Aug 8, 2006 | 11:42 PM
WV_Bowhunter
Stage III
It's that obvious???? [] Sorry, I've owned this bike for four years and planned on getting the manual. Now I finally have a serious need for it. Thank you for your help!
Chris
Grovit
Mar 30, 2015 05:55 PM
billvaughn
Jul 21, 2012 07:26 AM
Mr1986FLST
EVO
Aug 7, 2010 10:01 PM
Wampuscat
Nov 16, 2008 05:20 AM
Psycho Steve
Sep 5, 2008 10:08 AM
