down on power
Old Apr 28, 2010 | 10:04 PM
sportyguy69's Avatar
sportyguy69
Default down on power
Well was running up the interstate with a buddy, riding kinda hard. He pulled away from me so I twisted the throttle. Bike was pulling good, hit 110 mph and the bike coughed and lost power, exhaust had a different tone, bike wanted to stall out if I didnt keep the throttle turned. Slowed down bike ran better on the rest of the ride. On the way home, it didnt want to idle with the clutch pulled in at a stop light. Exhaust did sound kind of different also on the way home. I am clueless on this one. Anyone got any ideas?
2002 Fatboy,carb, vance and hines big shots. Stage 1 air cleaner. 190 main jet, 52 slow jet.
Old Apr 28, 2010 | 10:10 PM
hemdog's Avatar
hemdog
Intake gasket leak?
Old Apr 28, 2010 | 11:39 PM
Other Sheep's Avatar
Other Sheep
Gas filter?
Old Apr 29, 2010 | 05:57 AM
Blk and Chrome's Avatar
Blk and Chrome
sounds like you got something in the jet, clean the carb and replace the filter
Old Apr 29, 2010 | 06:31 AM
Tom84FXST's Avatar
Tom84FXST
Alcohol in today's gas is a very efficient cleaner...it tends to loosen all kinds of crap in you tank that was more than happy to just lay there with "normal gas". Check your petcock screen. Disconnect the gas line from the petcock, run a longer line to a gas can...and either turn on your petcock or apply vacuum and observe gas flow. Unless your bike has been stored improperly, nothing big enough to clog a jet should make it past the screen...YMMV
Old Apr 29, 2010 | 08:10 AM
FastHoss's Avatar
FastHoss
I think I would check the petcock for blockages,test the vacum part of petcock to see if working right,intake leak spray test,if none of those things do a compression test.
Old Apr 29, 2010 | 04:12 PM
sportyguy69
I just had the carb off a couple of weeks ago and took it apart and cleaned everything. I was running kinda hard last night, I was thinking I probally sucked all the gas out of the bowl faster than I could pump it in. But a clogged petcock screen would slow the gas going to the carb. I will have to check that. I have already sprayed the intake gaskets and around the carb with starting fluid looking for a intake leak. All good there. Thanks for the help everyone I will let you know what I find.
Old Apr 29, 2010 | 05:12 PM
hemdog's Avatar
hemdog
Did you spray around the intake where it goes into the head? Had the same problem with mine and it was the intake gaskets. Was the manifold loose at all?
Old May 1, 2010 | 03:52 PM
sportyguy69
yes manifold bolts were tight and I sprayed starting fluid around the manifold gaskets everything is good there. I have rode over 500 miles since my problem the other night and the bike hasnt missed a beat. Guess I just cant run 110 mph down the interstate anymore....lol.
ss313
EVO
15
May 8, 2016 10:02 AM
Winweg12
Feb 19, 2016 03:33 AM
The General55
Aug 24, 2014 01:15 PM
JasperJr
Exhaust System Topics
Nov 14, 2012 07:16 AM
Robert37
Sep 1, 2010 12:51 AM
