Carb jetting questions
Old Apr 27, 2016 | 09:57 PM
ss313's Avatar
ss313
Default Carb jetting questions
I usually just figure this kind of thing out by trial and error but like to see if any of you have any input. My bike is a 97 Superglide. The only mods that I know of are a K&N type air filter and Python3 2 into 2 pipes. It currently has a 45 low and a 180 high jet with a NOKK needle. It runs fine except that when you close the throttle (think compression braking) I get some very light exhaust backfiring and if I roll back on the throttle it will backfire out of the throttle. Otherwise it runs fine, pulls hard, and doesn't backfire.
When trying to set the idle mixture I can get it to stumble when turning it in but I can back it way too far out with no affect.
I assume that I need to put a larger low jet in it. Do you think a 48 will be too big? How about shimming or changing the needle?
Old Apr 27, 2016 | 10:51 PM
92Fatty's Avatar
92Fatty
Have you checked it for any leaks around the intake? Jetting sounds good to me.
Old Apr 27, 2016 | 11:49 PM
Spanners39's Avatar
Spanners39
48 idle jet and 190 main with a needle shim should fix it.
Old Apr 28, 2016 | 05:13 AM
ss313's Avatar
ss313
I suspected an intake leak so I replaced the seals and the carb boot. I used the paper trick on the exhaust gasket area and didn't find any leaks.
I have a kit coming with both of those and some shims. I'm not sure about the 190 because it runs fine on the top end now but I guess I'll see,
Old Apr 28, 2016 | 07:56 AM
Axis39's Avatar
Axis39
It can still run fine, if a little lean. I've always believed it's better to start a little fat. And, it does sound like your low jet is a bit small, at least.
Fredericksburg? I live in Falmouth..... And should be riding again soon.
Old Apr 28, 2016 | 08:26 AM
Racepres's Avatar
Racepres
2 into 1?
I have always experienced Backfires with a 2-1 exhaust...Certainly when accompanied by a Dual Fire Ignition. Betting a set of staggered duals would Make the Backfire go away...Probably Not be a Performance gain tho.
Old Apr 28, 2016 | 10:57 AM
Uncle G.'s Avatar
Uncle G.
Id try the next size up pilot jet.
Old Apr 28, 2016 | 07:31 PM
ss313's Avatar
ss313
Thanks for the replies. I'm going to start with a bigger idle jet and then shim the needle if it needs it.
Axis,
Let me know when you're riding again. We can check out some of the roads. I know a few and am always looking for new ones.
Old Apr 28, 2016 | 08:02 PM
Ruggs59's Avatar
Ruggs59
I run a 48 and a 190 in my evo
Old Apr 28, 2016 | 08:25 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I have those same Pythons and have to say they are a real good 2-2 for an Evo. They really let the motor breath.
Woods W6 uild yielded 93/85
W8 yielded 95/93
And they sound real good. Old school....
