Engine running hot
Old Aug 15, 2006 | 04:01 PM
Dragonsoni's Avatar
Dragonsoni
Default RE: Engine running hot
Has anyone tried these Fuel Injection Modules on a stock bike for engine heat? 2006 FXSTI Also posted in another section with out much result.
Terry Comp TVII - ? Splicing and warranty issues for sure.
Would Perfer a module the doesn't require splicing and if I can get away without a dyno that would be great.
Arlen Ness Big Shot - does not require splicing
Cobra FI2000(R) - does not require splicing
Powercomander III Dyno required??
Schedule - Stock bike, pipes after break-in or later, not sure I will ever do the air cleaner. That's it for performance mods.
Thanks
Old Aug 15, 2006 | 04:23 PM
sleepneagle's Avatar
sleepneagle
It's a new engine that has not been broken in yet. Get that first 500 so you can run it up past 50. Then at 1000 you have a service check and have them check the ECM settings.
Old Aug 15, 2006 | 04:27 PM
KY23's Avatar
KY23
I installed the Powercommander III usb first thing..before I changed pipes, A/C or anything else. It did lower my temps some and I'm sure I could have lowered them even more if I tuned the bike. I waited until I had the A/C and exhaust before I really started working with the tuning. Just installing the PCIII you can lower temps. You do not have to have a dyno to install the PCIII correctly. If you really wanted to get 100% out of your install I'm sure a Dyno would help but just every day driving you can install a PCIII and use the stock maps to get your bike running right.
Kwayz
Oct 15, 2015 07:37 AM
waikiki
Oil Archive (no new posts)
Aug 10, 2012 03:48 PM
trane0605
Jul 9, 2008 03:56 PM
flandig
May 30, 2007 09:14 PM
callieblue
May 29, 2006 12:55 PM
