Does this look good, I just installed V&H big radius and a SE air breather and the local Harley dealer tuned the bike. This is the sheet they gave me, does it look ok?
on a basic stage 1 you can expect 4-10 hp gain and 4-10 tq gain depending on what you have for a tuner ie..dobeck,pcIII,pc5,se exc exc.....all combos are differant...
The bike is a 2008 fxstc, not sure what they did, I gave them a Sert tuner and this is the paper they gave me back so I assume they did the download?
More than likely not a download but a tune. They used your SERT along with an air/fuel monitor to tune the bike. Without the Air/fuel mix it's hard to say. Even then it's hard to tell from just the sheet. I would say if you are happy with it and it runs good that is all that matters..
The numbers themselves don't mean all that much as it varies from dyno to dyno an the atmospheric conditions play a role. the curves look like a solid improvement over what you already had.
