Need some mechanical advice.....
Old May 18, 2010 | 08:06 PM
mdanehart's Avatar
mdanehart
Default Need some mechanical advice.....
Good Evening..I have a 93 Evo Softail. The top end was just redone about a thousand miles ago with a multi angle valve job, ported the heads, new rings and a Headquarters HQ-29 cam. First of all the bike runs like a bat out of hell and pulls extremely strong from idle to well I have not had the ***** to go past 5000 rpm with the screamin eagle ignition set-up.
Now here is my issue..When I start the bike (cold) I get a big puff of blue smoke for less than a second, nothing after that? It only seems to appear when the bike is cold and not after riding a short or long distance? No noticeable amount of oil consumption? By the way the issue has just started doing this about a week ago.
Any ideas or input?
Thanks in advance..
Old May 18, 2010 | 09:20 PM
streeteagle's Avatar
streeteagle
A puff of blue smoke is definitely oil related. Most likely your rings have'nt completely seated or oil is getting past you valve guides. Give it some more miles & keep an eye on your oil level. By the way, goose it good every now & then, if it's the rings, it will help seat 'em. By the way, I'm originally from Richwood, fellow West Virginian!
Old May 18, 2010 | 11:01 PM
Wanna Ride's Avatar
Wanna Ride
He pretty much summed it up. I wouldn't be overly concernd just yet, but keep an eye on it.
Old May 19, 2010 | 01:01 AM
Bluehighways's Avatar
Bluehighways
Valve Guide Seals &/or Stem to Guide Clearance:
Your description is textbook perfect for this sort of failure.
When you shut the bike down when it's hot and then let it sit a long time (liker overnight) enough oil will seep down past the intake valve stem so that whe you first fire it up again a small amount of oil gets burned . . . ergo a puff of blue smoke. You're always burning a little but "little" is the operative word. It's only after hours of sitting that enough accumulates to give you a visable puff of blue smoke. So-o-o-o-o what to do? I'd say the folks who did your heads need to take a look at the guide seals they used and/or the valve stem to guide clearance. It's not something that will make your engine expire anytime soon . . . but niether should it be doing it.
Dazzauk
EVO
52
Apr 4, 2016 03:55 PM
marl
Shovelhead
11
Oct 25, 2014 01:51 PM
tahoe36c
Nov 12, 2012 04:15 PM
Iron_Kicker
Exhaust System Topics
May 25, 2012 02:14 PM
38knuckle
Shovelhead
Apr 3, 2008 06:20 PM
