Throttle Slop
Old May 21, 2010 | 06:55 PM
Budmiester's Avatar
Budmiester
Default Throttle Slop
Put a set of 16" Wild One Chubby's on my 08 Cross Bones. Changed over to a set of Barnett Black cables, (throttle/idle). Now I've got about a 1/4 twist slop in throttle response. Any one have any ideas?
Old May 21, 2010 | 07:35 PM
Rockyriver's Avatar
Rockyriver
You should be able to adjust it out. Does your cables have an adjustment? Its usually 3 or 4 inchs out from where the cables come out of the handgrip housing.
Old May 21, 2010 | 08:14 PM
Budmiester's Avatar
Budmiester
Nope. Slip ring compression fitting into the throttle hand grip and straight cable to the throttle body on the engine. No adjust like the clutch cable.
Old May 21, 2010 | 08:45 PM
Rockyriver's Avatar
Rockyriver
If the cables have no adjustments, then its out of my league on what to do.
Old May 21, 2010 | 09:04 PM
sliver's Avatar
sliver
That's strange I thought every t/i cable had adjustment.
Old May 22, 2010 | 08:29 AM
cwsharp's Avatar
cwsharp
Something is not right... I don't think that Barnett makes a clutch or throttle cable without an adjustment connector in it... at least for a Harley. You might have received something for a British bike, which has the adjustment in the cable receiver at the hand control. Or, something for a custom application.
Old May 22, 2010 | 06:27 PM
Budmiester's Avatar
Budmiester
Of course that would just figure. Darn near every project I undertake turns into "Never seen That Before". On the up side, I'm the king of FUBAR Projects! I'll keep yawl posted.
Old May 22, 2010 | 06:30 PM
m i k e's Avatar
m i k e
get us some pics mon
i'd like to see some british
thr/idle cable
Old May 22, 2010 | 06:33 PM
ranger56528's Avatar
ranger56528
Wierd.............
Old May 22, 2010 | 07:30 PM
Budmiester's Avatar
Budmiester
Color me dumb *** today. Adjustment at the end of the 90 degree bend coming out of the throttle. Problem solved. Thanks to all.
