need help..2001 softail standard
Old May 28, 2010 | 08:38 AM
SD_Nick's Avatar
SD_Nick
Default need help..2001 softail standard
I am working on my bros bike, 2001 softail standard. we want to put the lowered progressive springs in. 1st tube went very easy, no troubles. the 2nd tube however is being a witch. We can not get the fork nut off, seems frozen to the tube. I have tried every safe method I can think of (i.e. rags and hose clamps, oil filter strap wrench, pure hand strength, and a lil heat) we can not keep the fork from spinning. I am almost to the point of putting a pipe wrench on it ( below the lowers, and ofcourse sanding the rough spots back down.) Got any ideas for me?
Old May 28, 2010 | 08:59 AM
rdoucet's Avatar
rdoucet
You can try using an impact wrench if possible
Old May 28, 2010 | 11:54 AM
SD_Nick's Avatar
SD_Nick
sorry i misspoke guys. its actually a 2002 softail standard, also not the fork nut but rather the fork plug. Half round but we are able to use a 13/16 open end on it.
Old May 28, 2010 | 12:24 PM
Chopper Dave's Avatar
Chopper Dave
I used a bench vise and a set of bench vise protectors so that it wouldn't mess up the finish of my forks. Hope this helps.
Old May 28, 2010 | 12:34 PM
rdoucet's Avatar
rdoucet
J&P cycles sells a fork leg and tube holder kit made by Jims - part number is 910-943.
Take a look at the picture of the holder and you may be able to make something work similar if this is a one time use.
Old May 28, 2010 | 12:48 PM
SD_Nick's Avatar
SD_Nick
exactly what i need. thanks for the info! I think I can come up with something similiar.
Old May 31, 2010 | 12:38 AM
HarleyHam's Avatar
HarleyHam
Let us know how it turns out. I myself am about to embark on a similar procedure and on the same model I'm going with the progressive drop-ins. Want to level out the bike Low!
John
Old May 31, 2010 | 08:33 AM
handyhoward's Avatar
handyhoward
Put the axle back thru both sides and loosen each side before taking just one side apart... it keeps the fork from spinning...
misfitJason
Aug 25, 2014 10:37 PM
BellTired
Softail Parts
Jul 18, 2014 08:51 AM
DirtNap
Mar 3, 2011 03:35 PM
James23
Apr 9, 2008 09:12 PM
OneBlackFly
Jan 6, 2007 11:00 PM
