Springer question ... cross bones
Old May 28, 2010 | 07:04 PM
Crossb0nes's Avatar
Crossb0nes
Default Springer question ... cross bones
Hi all, have had my bike just a few days, has 200 miles on now from new.
Have a question about the springer front, is literally solid, not even any give when rocked hard at a standstill on the front brake. This sound right?
Had heard that this model needs to 'break in' the front suspension but I just wanted to check other new owner experience?
Many thanks in advance; a newbie
Old May 28, 2010 | 07:28 PM
Rakthi's Avatar
Rakthi
Sounds right to me ... even after 5000 miles mine is still solid at standstill, but works like a charm on the road. Keep in mind you have to have the torque setting on the rockers checked at ±500 miles.
Old May 28, 2010 | 07:56 PM
GymRat523's Avatar
GymRat523
you should see it moving as you ride and hit small bumps and it should dive a little when you stop with the front brakes but it soften s up a little with some miles. Sounds normal.
Old May 28, 2010 | 10:16 PM
McBonez's Avatar
McBonez
3rd Gear
I have about 6000 miles on my 08, its solid but when riding on a rough road you can see the front springs moving.
Old May 28, 2010 | 10:23 PM
meatsack's Avatar
meatsack
The springer should be serviced at 500 miles. Mine was very stiff upon delivery. The dealer told me mine was set up WAY too tight when they checked it at 500 miles. It was a far better ride after having it properly set.
Old May 28, 2010 | 11:20 PM
oct1949's Avatar
oct1949
there U go.... must be Ur first...
Old May 29, 2010 | 02:26 AM
IronAss's Avatar
IronAss
I have noticed that even after servicing the forks it is pretty stiff for the first 50 miles or so before it loosens up. Should start springing pretty soon.
zird00
Apr 10, 2010 06:53 PM
humbuster
Nov 20, 2009 12:26 PM
Hammy
Sep 30, 2009 09:12 AM
Ed45
Jan 31, 2008 07:51 AM
