Steering Head Adjustment "Fall Away" Test
Old Jun 20, 2010 | 08:53 AM
commander112's Avatar
commander112
Default Steering Head Adjustment "Fall Away" Test
I assume to perform this test properly all of the cables need to be disconnected from the handle bars, correct? As I look at it there are also calbes that would need to be removed from the front end is this also correct? Can you get decent results with the cables attached or is this a must remove task to get accurate results? Just lazy!
Mark
Old Jun 21, 2010 | 02:57 AM
Notorious688's Avatar
Notorious688
What is that fall away test you speak of?
Old Jun 21, 2010 | 05:42 AM
Rakthi's Avatar
Rakthi
The tech guys at my dealer say that only taking of the clutch should be ok.
The fall away he's talking about is for setting of the head bearings. You get the front wheel of the ground, apply a pointer and tap the front until the wheel "falls away" by itself. According to the distance between the 2 fall away points (left and right) you loosen or tighten your head bearings. (sorry too lazy to go and look up the actual values in the service book)
Old Jun 21, 2010 | 06:22 AM
jimmers1817's Avatar
jimmers1817
Couldn't do it on my bike with the cables on. Too much drag.
Old Jun 21, 2010 | 08:11 AM
KumaRide's Avatar
KumaRide
Did mine with cables. Used to get a clunk going over bumps. No more cluck and bars move freely. A wrench on this site says to just tighten the bolt to ~12 ft lb's - no fall away adjustment needed.
Old Jun 21, 2010 | 08:21 AM
tk353's Avatar
tk353
if you do the test grease it afterwards or it will throw off the test
Old Jun 21, 2010 | 09:36 AM
2DAKERB's Avatar
2DAKERB
Here's an example.
http://www.youtube.com/watch?v=PbPCIvtQGvY
TSwann88
Jul 16, 2017 12:03 AM
martin10
General Topics/Tech Tips
Mar 27, 2017 09:54 PM
Iron lHorse
Jun 4, 2014 06:26 PM
skully1200
May 4, 2012 05:13 PM
drnk_n_publick
Mar 9, 2011 09:11 PM
