Slight Rub
Old Jul 10, 2010 | 06:05 PM
Forge's Avatar
Forge
Question Slight Rub
So my front brake rubs slightly....It is not the bearing...asked an old local mechanic (not from Harley steeler)...he said that is normal for an 01 fatty.
1) Is he full of it?
2) Is it possible to adjust it out?
I did take it on a 150 mile chairty ride last weekend with no problems.
Thanks Forge.
Old Jul 10, 2010 | 06:07 PM
Blk and Chrome's Avatar
Blk and Chrome
if I rool mine it will rub a little. Not enough to cause a problem. It did it with the stock pads as well as the new ones, normal
Old Jul 10, 2010 | 06:55 PM
jlasoftail's Avatar
jlasoftail
my flstc rubs. I'd be surprised to find a set that doesn't.
Old Jul 10, 2010 | 07:17 PM
KumaRide's Avatar
KumaRide
Rubbing is normal. To test, go on a ride then lift your bike up. If your wheel spins ~1 1/2 turns then all is good. If it turns less than one revolution, clean pistons and pad pins. No adjusting, only proper cleaning and servicing.
Old Jul 10, 2010 | 11:27 PM
stevieg's Avatar
stevieg
Saw the title of this thread and I thought you were admitting to being a "slight RUB"....
Old Jul 11, 2010 | 02:07 PM
Forge's Avatar
Forge
Default Rub
Haa!! I wish..at least the Rich part...I do fully support the RUBS...cause the more they buy and get tired of the bikes...then more deals will arise...That is how I got my current bike...01 Fatty with 3500 miles...under book value...guess the economy has something to do with it also.
Windseeker
EVO
24
Jun 30, 2018 10:13 AM
CaptainKirk
2014-2024 Touring Models
May 2, 2015 10:10 PM
Mr.G
Wheels/Tires
Jul 14, 2011 08:27 PM
hogdvr
Aug 31, 2008 06:17 PM
SOCALHD
15
Jul 17, 2008 03:04 PM
