Stiffening shocks
Old Jul 13, 2010 | 09:56 AM
Albritton's Avatar
Albritton
Default Stiffening shocks
How do you stiffen the shocks on a softail?? I have a 2001 Heritage and it seems to bottom out when I ride my girlfriend and it annoys the mess out of me when it does and I heard that they can be adjusted
Old Jul 13, 2010 | 09:59 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Old Jul 13, 2010 | 10:15 AM
Albritton's Avatar
Albritton
OK thanks!! You think that will solve my problem? Will it make the ride quality any different?
Old Jul 13, 2010 | 12:34 PM
nvsteve's Avatar
nvsteve
Yes it will help the ride quality and keep you from bottoming out. If you're heavy or ride alot of 2 up, you're going to want to adjust them out quite a bit.
Old Jul 13, 2010 | 03:49 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
As he said, there is quite a range of adjustment. That being said I am never happy with stock shocks and put on an air ride so I can float on a pillow of air.
Drew
Old Jul 13, 2010 | 08:40 PM
nvsteve's Avatar
nvsteve
Drew
Good point. I hated the shocks on my Heritage.
Old Jul 13, 2010 | 08:48 PM
06Heritage's Avatar
06Heritage
Im trying to ajust my shocks .... when I try to turn the disc with the special wrench , I cant do it without the whole shock turning . Any Ideas ?
Old Jul 14, 2010 | 07:15 AM
nvsteve's Avatar
nvsteve
If I remember correctly, the whole shock does turn.
Old Jul 14, 2010 | 10:43 PM
tmitchellof PG's Avatar
tmitchellof PG
The shock body turns.
I change the setting on mine quite a bit, depending on if I am riding solo or two up.
I painted a white stripe on the bottom of each shock. This way I can count how many turns I have adjusted them and know that they both have been turned the same amount.
I learned it is best to back the shocks off just a bit if you are going to turn them all the way one direction or the other. This way they wont be jammed into place next time you adjust them.
I just barely snug the retention nuts, so that they also are not that hard to break loose next time. The retention nuts never have worked loose by themselves. I don't know why HD puts loctite on them, from the factory.
Tom
Old Jul 15, 2010 | 07:35 AM
nvsteve's Avatar
nvsteve
I also found that I could adjust the shocks with a strap wrench. By turning the body the plate moves as well. Much easier than using the tool.
