I have a 09 Heritage and wanting to raise the bars some and wondering how high of a set of risers I can go without having to fool with the cables ? Was thinking about around 4 inches !
i have a 09 heritage and wanting to raise the bars some and wondering how high of a set of risers i can go without having to fool with the cables ? Was thinking about around 4 inches !
can't tell you specifically about your bike but suggest...cover the tank and then take the top clamp off. Have a buddy measure the lift while you raise the bars as far up as they will go. Don't be afraid to manipulate the wiring and brake lines to squeeze a little more while testing. Remember that things change when you turn the bars from lock to lock. Note also the bars will pull back a tad due to the pitch on the triple tree. Just an idea that worked for me. Good luck!!
In '09, Harley went to taller handlebars on the Heritage (approximately 3 inches taller if memory serves me right), but probably kept the same length cables. 4 inches might be a stretch.
Originally Posted by DaSham58
Can someone tell me what a good set of 4" risers for my 09 Heritage?? and where to get them! Thanks.
I stopped by the local HD Dealer and one of the guys in the shop told me I could go 4" but that would be it!! That's all I want is about 3 or 4 inches.
you might wanna try 2" first. I got 2" pullbacks from J&P and now i'm thinking I should have got regular 2". Also I saw a heritage with 4 or 6 inch risers at a dealer and with the bars turned all the way to one side it hit the speedo.
The pull backs has that much of a angle I am appreciate you telling me this because that was the rout I was going!! What size would the bars on the Heritage be 1" or 1 1/2" Thanks again!! Wonder what about a set of new bars how high can I go maybe 14"
I have a 2010 Heritage and rececently installed a pair of Baron Kickback Risers. They are 4" with approximately 1 1/2" pullback. I kept the stock cables and there are no clearance issues. I'm 5-9 and they made a world of difference in my comfort level. I got mine from Dennis Kirk.
Where did you get the risers?? Thanks! Was there any change in the 09 & 10 as in cable length ??
