Mirrors vibrate excessivley
Old Jul 26, 2010 | 01:46 PM
rd89softail's Avatar
rd89softail
6th Gear
Default Mirrors vibrate excessivley
Anything over 50mph, I can't tell if there is a car
behind me.
Should I replace them, or is this normal on an 89 softail?
Can't tighten them any tighter.
Old Jul 26, 2010 | 02:03 PM
Kowan's Avatar
Kowan
The older evo does vibrate enough to make using the mirrors difficult.
You could try different handle bar riser bushings to see if they will do a better job absorbing the vibrations making it up to your mirrors.
Old Jul 26, 2010 | 03:01 PM
magnum629c's Avatar
magnum629c
I loved my old EVO it was a fun bike one day after a nice ride I looked up and the Mirror vibrated so excessivley it broke off !!! The funny part was the stem was still half there it broke the stem right in half. Maybe some handle bar changes would help..times like this a 6 speed sure help. One thing i was shocked about was with my twin cam bike the Mirrors dont shake one bit. Crazy part is i wish I had my old bike back this smooth stuff is not for me
Old Jul 27, 2010 | 04:15 AM
Notorious688's Avatar
Notorious688
Yes, they shake. As for what's behind you, why do you care? Okay fine... do a shoulder peek.
Old Jul 27, 2010 | 04:39 AM
eisterd's Avatar
eisterd
I would swap riser bushings and see how it is
Old Jul 27, 2010 | 07:58 AM
tas_todd's Avatar
tas_todd
When I changed to poly riser bushings (installed 14" apes) I now get more vibs in the morrors. I can lift up my hand a little and steady it when I take a peek.
Old Jul 27, 2010 | 03:16 PM
rd89softail
6th Gear
Thanks, looks like I'll try new riser bushings.
Old Jul 27, 2010 | 04:21 PM
07DDreamHD's Avatar
07DDreamHD
I have a buddy that owns a dyna rubber mount. He had the same problem after getting above 50 mph. We all put the dyna beads in our tires and removed the weights from the wheels. His mirrors no longer vibrate above 50 mph. It may be a combination of the engine vibration along with the balancing of the wheels. When the wheels are balanced, they are not done so with a vibrating engine. I have the counter-balanced and still use the dyna beads. The beads will go to where they are needed inside the tire for balance. It will create an extremely smooth ride. For your bike, you will need one ounce for the front wheel and two ounces for the rear wheel.
Old Jul 27, 2010 | 05:07 PM
DC Mike's Avatar
DC Mike
Try these, they will cut the vibration in your hands and your mirrors...
http://cgi.ebay.com/ebaymotors/GRIP-...Q5fAccessories
V-Twin and the like all sell similar items...
Mike
Old Jul 27, 2010 | 07:08 PM
meatsack's Avatar
meatsack
It's a Harley...doesn't everything vibrate excessively?
