Brake Scraping?
Old Aug 31, 2006 | 01:42 PM
smittyp83's Avatar
smittyp83
Default Brake Scraping?
I've noticed a scraping sound coming from my front wheel, almost as if the brake pad was scraping on the rotor, but it doesn't do it when I squeeze the brake. The bike's only got 1400 miles on it so I know the brakes are still good. I just had my 1k check up and mentioned it to the dealer, but they didn't find any problems. I noticed it on my old Sporty as well.
It's most noticable when I'm moving the bike when it's not running (probably just because I can hear it better!)
Any ideas on what this is from?
Old Aug 31, 2006 | 01:57 PM
dert's Avatar
dert
Default RE: Brake Scraping?
normal.
Old Aug 31, 2006 | 03:37 PM
panamoncreel's Avatar
panamoncreel
I had a metal on metal repetitive squeal when moving after picking my bike up from it's 1k service. I brought it right back and the jack@$$ said he'd never ridden a Springer before and thought when test riding it that sound was normal. [:@] Turns out they hadn't tweaked the rotor / caliper just enough to rub.
If it's metal on metal, get it checked. If it's a "sifting" sort of non-terribly-abrasive sound, probably normal. My Warrior always had a sifting type sound between the rotor and brake.
Good luck.
Old Sep 8, 2006 | 12:30 PM
jdmbackdoc's Avatar
jdmbackdoc
Hey I get the same noise on my 06 Fatty from the front rotor. Thought I would ask about it at the 1K service next week. Jim
Old Sep 8, 2006 | 12:36 PM
Hdbiker1450's Avatar
Hdbiker1450
Totally normal. See the thread on 'Floating Rotors'. They say that the braking is better, and the sound goes away. I agree, sounds like sh** to hear it at slow speeds.
Old Sep 8, 2006 | 03:02 PM
Cessna172's Avatar
Cessna172
Might try organic pads.
[sm=icon_cheers.gif]
Old Sep 9, 2006 | 01:42 PM
SCHAEFFER's Avatar
SCHAEFFER
5th Gear
I believe it also has to do with the drilled rotors. I know that drilled and slotted ones on cars are noser thn regular ones so I believe this would be true for motorcycle ones also.
Mine on my 05 Standard does it and I don`t worry, just crack the pipes and you can`t hear it anymore.
Morpheus515
Feb 10, 2014 10:31 AM
notnutts
Jun 20, 2012 07:35 PM
20STREETGLIDE08
Jun 14, 2010 09:09 PM
lhcstreetbob
Nov 3, 2009 02:06 PM
ctsbob
Aug 27, 2007 07:51 PM
