help with noise?
Old Aug 2, 2010 | 01:18 PM
ex99125b's Avatar
ex99125b
Default help with noise?
new to HD, my FLSTFB (3000 mi) makes a strange noise if I accelerate in too high of a gear...yes, I know...dont do it. OK fine. But Im curious about the noise anyway, Id like to understand the bike better. Lets say I have to stop quick with no time to downshift and immediately re-accelerate ( I said ok...I wont do it anymore) I hear a strange metallic noise that sounds a little like a metal cable being cut under tension...what is this? Any one understand what Im talking about?
Old Aug 2, 2010 | 05:10 PM
Bikenator's Avatar
Bikenator
From: in a trailer next to a ditch in South Florida
Sounds like you are experiencing what is commonly known as "pinging". This is the sound of pre-ignition/detonation. If carried to extremes it can seriously damage the valve train and if under heavy load and continued throttle, can burn a hole in pistons! It is a condition casued by self-ignition of the "end-gases" of the fuel/air-mix in the combustion chambers. Obviously, it can be extremely damaging if you fail to back off the throttle and downshift.
Make certain that you only use hi-test 91-93 octane fuel and USE YOUR SHIFT LEVER!
Old Aug 2, 2010 | 06:15 PM
Other Sheep's Avatar
Other Sheep
Donny Peterson once said the worst thing you can do to the Harley tranny is accelerate in too high of a gear. It puts extreme pressure on it and will kill it faster than anything else. Try learning how to downshift before cracking the throttle.
Old Aug 2, 2010 | 10:03 PM
flh80's Avatar
flh80
You right! Don't do it!
Old Aug 3, 2010 | 07:40 AM
tk353's Avatar
tk353
yes ping and mine did that for years until i got a new fuel filter. my bike also sat for a year before it was sold. when i changed the filter you could not blow air threw it. it now runs smoother and faster than when it was new
Old Aug 3, 2010 | 11:50 AM
Crossb0nes's Avatar
Crossb0nes
Its the sound of your transmission self destructing ...... I'm not sure if its fun to listen to but if you can afford it ....
Old Aug 3, 2010 | 02:34 PM
ex99125b's Avatar
ex99125b
I like destruction n' all but not on my dime. Its only happened twice, but I suppose thats enough...strange noise tho, very science fiction-warpy sound. Not engine pinging.
Must-be-more-careful
thanks
mcdaniel52761
2014-2024 Touring Models
Jun 22, 2015 11:33 AM
shaneK
Jul 13, 2013 10:20 PM
JimmieJack
Exhaust System Topics
14
Apr 4, 2012 11:19 AM
03 Softail
Jul 15, 2011 06:33 AM
trasher
Sep 13, 2005 11:38 AM
