Lowering a Springer?
Old Aug 17, 2010 | 10:24 AM
DocJ's Avatar
DocJ
Default Lowering a Springer?
Alright...I may be able to lower the Bones here in a month or so! I'm very excited about this. However, I've ran into a snag. It is possible to lower the front end of a springer? So far, I've had three people tell me I'd have to literally CUT my forks and re-weld them together if I wanted it lowered. It does not sound like good times to me, and I don't want to bother with getting a new front-end. However fun that may be.
My main concern is with looks. I think CrossBones look great lowered. I know most don't bother with the front-end, but I have a concern. Having it lowered two inches in the rear would result in a "slanted" look. I currently still have the stock "looking" pipes on the bones, and this modification would result in my pipes looking lopsided. I would really prefer them to be straight and even with the road. I don't want my bike to look dorky.
I guess my final question is this: Should I lower the bike in the rear and just change my pipes out so the slant isn't so noticeable? Or, is there an actual way to lower the front?
Thank you all for any input, advice, etc!
Old Aug 17, 2010 | 10:42 AM
Cheesecake's Avatar
Cheesecake
Burly makes a springer front end lowering kit....
no cutting involved...
I'm sure Dr. V could get you a deal on it!
CC
Old Aug 17, 2010 | 10:43 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Don't worry about the front is my opinion. Here is mine with the rear slammed and the front not lowered at all. I prefer having extra travel in the front to soak up the bumps. I don't ride it slammed like this very often regardless, but I think it looks great. LOL
Drew
Old Aug 17, 2010 | 10:50 AM
DocJ's Avatar
DocJ
I will have to look into the Burly one. Thank you for the suggestion, Cheesecake. Did you use that on yours?
Drew, your bike is amazing in more ways than one...I'm not so sure mine could pull it off as well as yours. lol. How much is the rear lowered on it?
I'm thinking 2" in back, maybe 1" up front? I still want to retain a nice ride, but since I'm not looking at air-ride (cost) it would not be adjustable. Any suggestions as far as that goes? I'm mainly looking at progressives or a lowering "kit" to lower the rear...leaning more toward the progressives at the moment.
Thanks, again!
Old Aug 17, 2010 | 11:12 AM
Cheesecake's Avatar
Cheesecake
No suspension mods on my bike....
I scrape the floorboards now... I can only imagine it I lowered it
My rear fender hugs the tire in back... and I'm naked up front... IMO it looks right....
CC
Old Aug 17, 2010 | 11:23 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
In that pic my bike is slammed 4.5".
Old Aug 17, 2010 | 11:35 AM
hspring03's Avatar
hspring03
Lowering the front will have an awful ride........
There are rocker kits and spring kits out there....BUT.
Leave the front alone...
Old Aug 17, 2010 | 04:15 PM
DocJ's Avatar
DocJ
CC
Huh...well, I'm surprised. Most people that go with that style rear fender lower the bike. However, I think it looks really good. You are tempting me to just leave my suspension alone all together! What fender kit did you use?
Your bike does look great. It has "personality" with a splash of panache.
4.5 inches! Wow...well, if that's the case, then I guess lowing 2" in the rear really wouldn't make a huge slant angle. I am hoping to get the good looks of a lowered bike, still retain some good ride, and NOT look goofy doing it. So far, I'm thinking the 2" would work pretty well.
I just can't believe you had room to lower that far...and, it doesn't look horrible. Hm...maybe I will leave the front alone.
I am not entirely sure to what you are referring when you mention the rocker kits and spring kits. Could you explain? Also, why would lowering the front be awful? I could guess, as the front does take a beating, and road feel would be transferred to the hands in a more intense level than stock, even lowered as little as one inch. But, any further commentary on the subject would be welcome.
Guess I'm looking for more back-up on opinions...
Thank you! I appreciate all input into the subject.
Old Aug 17, 2010 | 06:19 PM
back again's Avatar
back again
Just went thru this with my Bad Boy. I used the Burly kit and was not that impressed with the ride after I did it.the front end got a heavy feeling to it.Harder to get upright off the stand and low speed handling required alot more attention.Took it back off and I'm happy again.While the inch and a quarter lower ride looked good but the trade off in ride quality was not worth the look to me. I'm hooked on the springer ride.save your bucks for an air ride set up and enjoy the best of both worlds.
Old Aug 17, 2010 | 07:29 PM
DocJ's Avatar
DocJ
Just to clear things up a bit...sorry, I must confuse easy.
The Burly kit you used; was that for the front, rear, or both? Guess I'm not sure if you are recommending to not lower the front, period. Or, if you are simply saying to save my money for the real deal in the rear.
