Clunk!
Old Aug 18, 2010 | 03:02 PM
Bikenator's Avatar
Bikenator
From: in a trailer next to a ditch in South Florida
Originally Posted by wlbowers
The transmission is a constant mesh. that means all of the gears are always in contact with their counterparts.
When you shift you are moving what is called a dog between gear groups. If you look at the left gear cluster at the top you will see them. 6 around the shaft.
When they drop into the receiving cluster with torque applied that is the clunk. That clunk is Harley. Nothing wrong with it. If you want super quiet you shouldn't have bought a Harley.
Great explanation and photo!
Harley-Davidson uses engagement dogs not synchronizers. Synchros are used in manual shift cars and many foreign M'cycle transmissions. The suggestion to hold the clutch in during starts and holding it in for a while before enaging 1st gear helps a lot and is a good safety tip. Keep the clutch in proper adjustment (both cable and clutch pack) to minimize clutch drag when dis-engaging.
My transmission lube choice is Mobil 1 75w-140 synthetic.
Old Aug 18, 2010 | 07:43 PM
Firemed509's Avatar
Firemed509
Originally Posted by DocJ
It seems to be a normal Softail trait. Use synthetic in the tranny and that will help a lot.
+1... I changed to syn3 and it is not so loud.
Old Aug 18, 2010 | 08:00 PM
08rock's Avatar
08rock
Thanks . I don't mind the klunk as long as it's not causing any damage
Old Aug 19, 2010 | 11:05 AM
Man In Black's Avatar
Man In Black
Worry no more, it's normal. You will actually learn to enjoy it. It is part of the Harley experience.
Old Aug 19, 2010 | 11:07 AM
HOG_0308's Avatar
HOG_0308
Buy a gold wing and stop complaining. its a Harley, its suppose to bang and pop and have things fall off going down the road.
Old Aug 19, 2010 | 02:03 PM
akhenaten's Avatar
akhenaten
Clunk is good...at least you KNOW that you are in gear
Old Aug 19, 2010 | 07:45 PM
Jim Kraft's Avatar
Jim Kraft
I had a 68 Honda 160 Scrambler that clunked also. It was fun, but sure not a Harley. My old 1942 "45" hand shift clunked. On my 84 Sporty, I use to watch the rear chain when I put it in gear, just to watch it bounce.
Old Aug 20, 2010 | 07:10 AM
Harleyrider_49's Avatar
Harleyrider_49
That's a Harley, dude....ride it,and forget it!
Old Aug 20, 2010 | 08:51 AM
KumaRide's Avatar
KumaRide
Nothing better than sitting at a red light, light goes green, shift into 1st and CLUNK!!! lol
Old Aug 20, 2010 | 01:38 PM
kerrycorcoran's Avatar
kerrycorcoran
clunk - should be music to your ears
