Fatboy fallaway
Old Aug 25, 2010 | 07:34 PM
mplecha's Avatar
mplecha
Question Fatboy fallaway
I'm trying to set the fallaway on my fatboy, but the shop manual has me confused. I pulled the cap off the top triple tree, and underneath it was the stem bolt and washer. If I remove that, all I see is the stem itself. Am I supposed to use the stem bolt to make the adjustment? I have the lower pinch bolts loose. What am I missing here? I don't normally get this confused, but everything that came up in a search mentioned a star shaped nut that I don't seem to have.
Old Aug 25, 2010 | 09:36 PM
Other Sheep's Avatar
Other Sheep
Use the stem nut.
Old Aug 25, 2010 | 09:42 PM
mplecha's Avatar
mplecha
That's what I thought. Thanks!
Old Aug 26, 2010 | 08:26 AM
Swilkins's Avatar
Swilkins
There's probably a pinch bolt on the upper part of the stem too. At least there is on my heritage
Old Aug 26, 2010 | 12:13 PM
tk353's Avatar
tk353
loosen the pinch bolt, snug the top of the stem until it is right. tighten the pinch bolt and check again and then grease the bearings with marine grease.
rainsong
EVO
14
Nov 13, 2020 10:33 AM
tas_todd
Apr 30, 2015 11:20 AM
Hodgewater
Jan 25, 2010 06:01 AM
Johneb48
Aug 15, 2007 10:20 AM
Johneb48
Aug 7, 2007 12:49 PM
