How to change the brake pedal on a Rocker C
I'm new here and didn't have time to fully introduce myself... This, I will do as soon as I solved my problem...
I changed lots of parts on my 2009 Rocker C, and now I just received the final part (for this week), my rear brake pedal...
I removed the cutter pin and the bolt to realise that the pedal can't be removed easily because it won't clear the master cylinder shaft ('cause of the foot peg holder)... Is there some trick to remove that pedal, or do I have to remove the master cylinder first ????
Thank's for your help !!!
Thanks for the advice j33ptj, I have the FSM but I think the information in there was just not enough for me... Maybe someday with more experience...
... Or maybe it's just easier to ask you guys and get the answer in 2 minutes...
