Why do we put 75-140 weight oil in our trannys when the MoCo recommends 20-50?.
Seems if a tranny was built in such a manner that a thinner oil provided better lubrication it would only follow that a heavier oil could be too thick to get into certain areas and wouldn't drain the metal wear particles as well.
I think I'll dump the heavy stuff in our bikes and go back to a stock weight oil.
Viscosity for gear oil is measured differently than engine oil. I think 20-50 engine oil and 75-140 gear oil are pretty close. The Service Manual for my '07 Bagger specifies use only Formula + in the transmission. No mention of 20-50 engine oil. High quality oils are available to meet the specific needs of engines and trannies these days. I prefer to take advantage of that and not use the one size fits all marketing of Harley's Syn 3.
Gear whine in a tranny is not a defect. I remember the school bus whining through the gears when I was a kid. The old 4 speeds in muscle cars whined, it's normal. If people are putting heavier oil in their trannies to reduce the whine they could be creating a real problem where none existed. When gears wear they howl, thats a problem that has been masked by using heavier lubes, even saw dust, for years.
Should be done with the install sometime next week and I will send your money!
