Removing primary cover
Old Aug 30, 2010 | 06:36 AM
heritage jim's Avatar
heritage jim
Default Removing primary cover
I have all the bolts out but can't get the cover to come loose.Any tips?
Thanks
Jim
Old Aug 30, 2010 | 06:41 AM
Jim Kraft's Avatar
Jim Kraft
Remove the chain inspection cover. Two of the bolts go into the case.
Captain Itch's Avatar
Captain Itch
Sponsor
If you are sure you have all of the bolts out put one back in and hit the cover with the back of your hand,or a rubber hammer.The bolt that I had you screw in is so it does not hit the floor when it comes loose...Good Luck
__________________
www.Captain-Itch.com
Old Aug 30, 2010 | 06:48 AM
heritage jim
I forgot the bolts on the inspection cover.
Thanks
Jim
socobandit
Oct 18, 2013 09:33 PM
Good_Apollo
Jul 4, 2012 08:19 AM
Klymax Kustoms
Mar 24, 2010 07:21 PM
02glide
Nov 7, 2006 01:51 AM
carguy9497
Oct 7, 2006 11:45 PM
