TC-88B and cough/pop
2003 Fat Boy
stock engine
K&N air filter
V&H Big Shots
Bought bike w/8,100 miles on it, now has 21,000 (or so). Bike ran well when purchased and until 3-4 weeks ago. Until then, pops on decel and a cough or two only when cold (20 to 40 deg F) outside without warmup. Now, coughs at low RPM all the time (not at idle, but anything above for a little way) and pops on decel at just about any speed.
Here's what I've tested, and the results:
- Exhaust seems solid at the manifolds (doesn't move, tight)
- Intake manifold seems solid, no leaks (WD-40 test)
- rear cylinder plug looks very slightly black
- front cylinder plug had white residue caked on it
- gold jet (toward air cleaner) shoots gas here and there and always when I 'get on it'
- at higher RPM, the main jet seems active, slide rises
- air filter looks a little dirty
I replaced the front plug and cleaned the air cleaner. Bike runs 'better', but displays all the same symptoms as before at a slightly less frequent level.
I know there are several things I could immediately do to improve things, but the fact is that I - knowingly - changed nothing, and the bike's performance has changed. I need to find out why, fix it, and then we can chat about pet improvements!
Ideas guys? I'm not the gearhead I need to be, but I can find the major parts. What needs to be checked next, and how?
Thanks in advance,
R
