fuel pressure regulator problems
Old Sep 20, 2010 | 08:34 PM
nomaster's Avatar
nomaster
Default fuel pressure regulator problems
I pulled the fuel tank module out of my train today hoping it had a hole in the fuel line. turns out the fuel pressure regulator is cracked and not keeping it seated anyone know if harley sells this separately?
Old Sep 20, 2010 | 08:54 PM
Ruralmed's Avatar
Ruralmed
Yes, dealer quoted me $38.00 today. I got a tank of bad gas (sand) from Chevron and had to pull apart tank to clean. I will be replacing fuel filter and regulator tomorrow.
Old Sep 21, 2010 | 06:52 AM
tk353's Avatar
tk353
"the fuel pressure regulator is cracked" i guess you mean the bracket that holds the regulator. I have never had a bad regulator yet. you need a special tool for the hose clamps.
Old Mar 29, 2024 | 01:55 PM
Jc sims's Avatar
Jc sims
Stage I
Default Ultimate hdf
Hey you don't exactly need a special tool for the clamps. Just cut off with side covers if you don't own a pair of nippers which you use of not regular hose clamps are fine just don't over tighten.
I'm just saying there is always a way that can work without buying another tool. When I upgraded the cam tensioners on my 01 Softail I made one that looked much like the Jim's tool but was made out of a socket
Jc
Old Mar 29, 2024 | 02:27 PM
GalvTexGuy's Avatar
GalvTexGuy
Instead of reviving ancient threads, why don’t you introduce yourself in the Welcome Area Forum. Then, take some time to get acquainted with the site? After you do, then you’ll start to get the hang of things.
Loc_Tite
General Topics/Tech Tips
Apr 29, 2020 09:31 AM
olongapo1
May 27, 2014 11:49 PM
belsebub36
Blowers/Turbos/Nitrous Oxide
Jan 16, 2014 02:27 PM
KevinKruuz
Jul 29, 2012 07:12 PM
KevinKruuz
Jul 29, 2012 06:47 PM
