Engine cutting off
Old Sep 26, 2010 | 06:16 PM
Hustlercharlie's Avatar
Hustlercharlie
6th Gear
Default Engine cutting off
Have a 2000 Fat Boy 24k on the meter. While riding at highway speed,or in teh 35-50 range,occasionally it will seem to run out of fuel. Sometimes it will restart imediately, other times waiting a few minutes will start it. Whats up with this?\r\n
Thanxs
R.C.Steger,Kentucky
Old Sep 26, 2010 | 07:57 PM
snook592's Avatar
snook592
Carb or FI ????
Old Sep 26, 2010 | 08:47 PM
Hustlercharlie
6th Gear
Originally Posted by snook592
Carb or FI ????
Carb,Sir
Old Sep 26, 2010 | 08:52 PM
the blob's Avatar
the blob
i ck petcock vacume line and if not id ck coil+voltage regulator.
Old Sep 26, 2010 | 09:28 PM
Hustlercharlie
6th Gear
U 'da Man Blob..thank you sir checking first thing A.M
Regards
Rich in Ky
Old Sep 26, 2010 | 10:58 PM
dickey's Avatar
dickey
Had a Goldwing (sorry) that used to do the EXACT same thing--at highway speeds,it would cut out 1 cylinder at a time until it was dead--just like running out of gas. dealer replaced just about every component on the bike under warranty having to do with the engine running--couldn't fix it. I discovered the problem myself purely by accident--turned out to be a CLOGGED FUEL CAP VENT. Hope this helps.
Old Sep 27, 2010 | 07:49 AM
Hustlercharlie
6th Gear
Thanx for this.. another thing to check
Fegards
Rich in Ky
Old Mar 16, 2011 | 11:38 AM
Hustlercharlie
6th Gear
Default update
Thanxs
R.C.Steger,Kentucky
Been off the net for quite a while,but wanted to update this. The cause was electrical,and very minor. Removed the speedo cowl,there is a five prong connector under it. Connections coroded and loose. Small flat tip scraped and reseated wiring into connection. Problem solved! Thax to all who contributed
HC seven niner
rphillips
Oct 20, 2014 11:17 AM
loner19532004
Carburetor Related
Nov 29, 2012 05:38 PM
iceman31488
Sep 11, 2012 06:09 PM
Bear2000fatboy
Mar 24, 2012 05:39 PM
jb27
Aug 17, 2008 04:04 PM
