Stalling issues
Recently, my bike stalls when I pull my clutch in intermittently. It starts right back up every time. I could anticipate that it would stall because my bike would pop when I would close the throttle and it would idle very slow. We contacted Vance and Hines and they gave us settings in increase the amount of fuel at idle. My speedometer went to zero once when I was cruising at about 60 but that just happened once (very scary!). We used a voltmeter and everything checked out fine. The spark plugs look good also. My husband does all the maintenance on it according to the service manual. My bike never threw a code.
After we changed the battery and adjusted the fuel pack, I rode about 700 miles with no issues. My speedo still works fine (when it failed, my turn signals still cancelled) but it is stalling again. It isn't popping when I let off the throttle, it just idles very low intermittently when I pull the clutch in. It doesn't matter how much fuel I have in my tank. I have been riding in 45-80 degree weather.
We're going to increase the idle speed a little more to see what happens.
Someone else had the same problems with their Deluxe and got rid of their fuel pack and it never happened again.
Does anyone have an ideas where to start before I bring it to a shop?
Any help would be appreciated!
Similar events have been happening to my STC, doesn't matter how hot or cold, full or empty tank, etc. If I'm going, pull in the clutch and stalls. I took it to the dealership and mentioned it to them, they cleaned some sensors but claim that they couldn't find anything.
This doesn't happen every time I ride, sparatically really. Only mod I have is Rush 2.0" slip-ons.
If I roll the throttle a little it stops it from stalling but I can't always do it.
When my husband rode it and couldn't reproduce it. I know if I bring it to a shop they may keep it for weeks and find nothing.
I'll readjust some settings on the fuel pack and see what happens. If it doesn't work, I may get rid of it and get it mapped or try a power commander instead.
I'll keep you posted~thanks!
07 FB, 6k miles, all stock, 3/4 tank of fuel, approx 70degrees. i did pull the aircleaner and checked the throttle body, it looked ok. when i plugged off the IAC port it idled to low and stalled.. i closed it off sloooooow to try and see if the base minimum air rate was ok.. i think it's too low myself.. with the IAC port closed it should still idle, but real low, just this side of stalling.. well thats how it is with cagers.. fuel injection is fuel injection in my book.
side note.. i did notice some train huffing smoke out the real cylinder breather tube, but the frt was clear.. is that normal or did i buy a used lemon last yr..
My '07 Deluxe stalled twice on a recent 3,000 mile trip. The second time it happened, it went completely dead while I was riding down the highway. Obviously I was concerned. However, after the second malfunction, I figured out that the bike's key was in my pocket, and it had turned the bike off when the key was moved around inside my pants. The bottom line? The key in my pants had turned the bike OFF.
Remember.......these newer bikes have the security system key on them, and if that key gets manipulated, it can literally cut off the power to your bike.
HD
