Progressive "drop in" springs for Heritage
Did my front end nuts on top of tree are not under pressure. I then took forks at to my mechanic to replace springs and seals. Use heavy weight fork oil.Saved some money and peace for mind that it was done rigth.
I have always used a large crescent wrench and put a piece of electrical tape on the jaws of the wrench
I've looked at pictures of these plugs...I'm thinking I could use some sort of socket to remove them?
Thay arnt that tight, a good quality cresent or an open end works
HAPPY HAPPY, JOY JOY!
Installed the lowering springs tonight! My thanks to everyone who offered their assistance. Job went pretty well. I ended up having to remove each fork from the triple tree, so I did them one at a time. Just to confirm, the slider caps are NOT spring loaded or under any pressure! Taking off the fork tube plugs was easier than I thought it would be. Just clamped the fork in a vise and used a pair of vise grips on the plug ends. The spring pressure wasn't as bad as I anticipated. I know that people recommended using the heavy duty fork oil. I asked one of the mechs at the dealership what they normally do. They use the type E fork oil. Said that the heavy duty would give a much stiffer/firmer ride. For now, I'll try it out, and if I don't like how it feels/handles, I can always drain it and go heavier. So, I have the rear lowering kit on the shocks, and I have the progressive lowering springs on the front end, and the Arlen Ness 1" lowered kickstand. Overall, I am very happy with the end results. Being vertically challenged, 5' 5", I can now place both my feet firmly on the ground! Again, my thanks to everyone. This forum is a valuable resource for the D.I.Y.!
I will take some pictures and upload them....I dropped the front, I guess, 2"?...I used a 3" spacer that progressive recommends....for the rear, the bolts say up to 2" lower, so I'm not sure. I can tell you this though. I can no longer slide my craftsman motorcycle/atv lift under my frame now :-(
Need to figure out a way to compensate for that?
